eBay Auction (no reserve)
Early next year I plan to auction off a display case full of projects that I have had published in the Silicon Chip magazine. These are the original prototypes (except for two of them) - these all were submitted to the magazine, photographed, and published in their printed & online editions. Each project comes complete with a copy of the magazine that they were published in (12 in total) No reserve auction starts @ $1, postage at buyers expense, will ship world wide!
So there you have it, a dozen of Silicon Chip's projects that were published between 2001 - 2006, three of which were marketed commercially as kits, original prototypes housed in a custom made perspex display case, a copy of each issue to go with each project. See project list below. Will upload eBay link once auction commences. No reserve auction starts @ $1 (Must sell, I'm sick and tired of seeing these things)
http://siliconchip.com.au/cms/A_101729/article.html PC-Controlled Mains Switch MK1
http://siliconchip.com.au/cms/A_101714/article.html Games Port Tester
http://siliconchip.com.au/cms/A_30755/article.html Continuity Tester (Reprinted in EPE)
http://siliconchip.com.au/cms/A_30495/article.html PC-Parallel Port Wizard
http://siliconchip.com.au/cms/A_30373/article.html Decision Maker MKI
http://siliconchip.com.au/cms/A_30519/article.html Digital Storage Logic Probe
http://siliconchip.com.au/cms/A_30808/article.html Programmable Timer
http://siliconchip.com.au/cms/A_105433/article.html Serial IO Controller (Reprinted in EPE)
http://siliconchip.com.au/cms/A_30709/article.html Flip-Flop Timer
http://siliconchip.com.au/cms/A_105834/article.html PC-Controlled Burglar Alarm
http://siliconchip.com.au/cms/A_106068/article.html Universal Keypad
http://siliconchip.com.au/cms/A_107104/article.html PC-Controlled Mains Switch MKII
Note: sale doesn't include ownership to any copyrights that the magazine(s) may have enforce. The prototypes are in mint condition (except for the burglar alarm), clear protective coatings have been applied to projects that have front panel artwork (they'll be good for a few hundred years :D). They're all assumed to be still working, but haven't been tested for quite sometime now since they were returned from the publisher. The eBay listing will contain further information along with many detailed pictures.
Happy biding SC fans!
Trent Jackson
Hard to put a price on them ...
Hard to put a price on them, like most oddities & collectibles - at the end of the day they're worth as much as someone is willing to pay! The value often comprises of two essential elements ...
1. Rarity
2. Demand
Much like a custom numberplate for a motor vehicle, there can only ever be one, and the more sought after it is - the more it's worth! The scenario here is very similar, except unlike a numberplate there's only one that exists in the entire world. Another example is the 1930 Australian penny, there's only 1,500 or so in existence! They're rare, they're highly sought after by thousands upon thousands of eccentric coin collectors, they typically fetch AUS 25K! The minted ones go for as much as 250K!
This will be interesting...
It's up!, the auction has started -- as usual I'm before schedule...
http://cgi.ebay.com.au/ws/eBayISAPI....:L:LCA:AU:1123
Thanks for the response Trent
I have two PCs ... and they are both high end XP ones. I have no access to any older PC technology I'm afraid.
If I could get the keypad side of things working it wouldn't be too much of an issue. Assuming that I can get the alarm config right by just trying each send from the PC s/w multiple times until it took .... I will just use the alarm with the keypad and SMS controller (which I already have built, tested and boxed ready).
I have tried reversing the tx/rx on the four way connector in the keypad unit (which would obviously do the same thing as swapping on the front panel.
Unfortunately all I ever get is a dddd whenever I hit the arm / disarm button. It responds so quickly with the dddd it makes me wonder if it is even waiting for a response from the main alarm which is odd in itself.
Can you remember what tones it is supposed to make ?
i.e. if you put in a correct code, what tone should it make ?
if you put in an incorrect code, what tone should it make ?
and is there a tone for a communications issue (like I suspect I have ... ) ?
Are any of the tones you remember the dddd ?
As regards the s/w, am I correct in thinking that the keypad codes you setup in zone config are completely independent of the users created in access control ? I have one owner setup in access control and I have tried setting the keypad codes to 0000, 1111, 2222, 3333 respectively. I have ensured that following hitting ok on zone config that the tx/rx led shows activity ... this makes me assume that the codes are being stored in the eprom correctly.
Have checked for dry joints .... all good connections. Have also tried different PICs in both main alarm and keypad ... and also swapped both crystals for new ones.
Although I struggled previously to understand your frustrations with SC ... my recent experiences with EPE have led me to sympathise.
If there is anything you can do to help I'd hugely appreciate it.
Best regards
Paul.
