Windows No Disk Error
I am getting this error when I click on File while using MicroCode.
I loaded a file from my A:\ and now no matter what I do I get this ERROR.
I have closed MCS, then ran MCS and then tried to open a file and I get this ERROR.
The only time it works is when I have a disk in A:\. Even though I am not trying to access A:\.
MCS has been working fine until I used a:\
How do I get around this problem without leaving a disk in a:\?
HELP
Thanks, Lee
Just a Guess....
Check the Default Folder in the MCS options.
Make sure it's not pointing to A:\
<img src="http://www.picbasic.co.uk/forum/attachment.php?attachmentid=2150&stc=1&d=119593610 0">
<br>
in case it doesn't work, which i doubt, use regedit to clean up everything should work.. be carefull
MicroCodeStudio Plus
HKEY_CURRENT_USER\Software\MecaniqueUK\MicroCodeSt udioPlus\Editor
and delete LastFile key
HKEY_CURRENT_USER\Software\MecaniqueUK\MicroCodeSt udioPlus\FileHistory
delete all keys, but leave default one
HKEY_CURRENT_USER\Software\MecaniqueUK\MicroCodeSt udioPlus\FileItems
delete all key as well, but leave default one
i don't have the regular version, but you should find something around the above.
HTH
Second guess ...
Un-check the Open last file(s) when application starts checkbox.
<br>
Thanks for the help. I unchecked last file box. Still had to put a disk into a:\.
I opened a file on C:\pbp and exited MCS. I removed the a:\ disk.
I rechecked the last files box.
I ran MCS again and tried to open a file and EVERTHING is working again.
Thank, Everybody, Lee
