I'm using the PCF8563P rtc, i can not get it to work
ive never used the i2c protocol before, so maybe ive messed it up?
ive looked through the posts already present on the forum concerning the subject
and cannot figure it out.
i would be grateful of any help
just using the basic 16f84 mcu
Code:'rtc pins
clk_pin var portb.5
data_pin var portb.4
'register address's
reg_seconds CON $02
reg_minutes con $03
reg_hours con $04
reg_days con $05
reg_weekdays con $06
reg_months_century con $07
reg_years con $08
reg_minute_alarm con $09
reg_hour_alarm con $0A
reg_day_alarm con $0B
reg_weekday_alarm con $0C
rtc_write var byte
rtc_read var byte
rtc_write=$a2
rtc_read=$a3
'time variables
seconds var byte
minutes var byte
hours var byte
days var byte
years var byte
'initial time variable values
seconds=0
minutes=0
hours=18
days=23
years=7
init:
lcdout $fe,1
lcdout "Real Time Clock"
I2CWrite data_pin,clk_pin,rtc_write,reg_seconds,[seconds]
pause 10
I2CWrite data_pin,clk_pin,rtc_write,reg_minutes,[minutes]
pause 10
I2CWrite data_pin,clk_pin,rtc_write,reg_hours,[hours]
pause 10
I2CWrite data_pin,clk_pin,rtc_write,reg_days,[days]
pause 10
I2CWrite data_pin,clk_pin,rtc_write,reg_years,[years]
pause 10
I2CRead data_pin,clk_pin,rtc_read,reg_seconds,[seconds]
pause 10
I2CRead data_pin,clk_pin,rtc_read,reg_minutes,[minutes]
pause 10
I2CRead data_pin,clk_pin,rtc_read,reg_hours,[hours]
pause 10
I2CRead data_pin,clk_pin,rtc_read,reg_days,[days]
pause 10
I2CRead data_pin,clk_pin,rtc_read, reg_years,[years]
pause 10
lcdout $fe,1 ' clear lcd
lcdout dec2 hours,":",dec2 minutes,":", dec2 seconds," "
