I'm looking for suggestions on a DAC.
Requirements (for the moment) are 5 volt single-ended supply, 8-bit parallel, and DIP package.
Anyone have any old (or new) favorites they'd care to recommend?
A R2R network and a generic op-amp would do the trick or the HPWM+filter plus an extra op-amp if you need more current is also one way. Then you only need one pin from the PIC.
I haven't found a need for an external DAC since these 2 ways have been enough this far.
/me
For the recommended methods by Jumper, care should be givet to the selection of op-amps, since the requirement is 5V power supply.
If you can tolerate serial communication, then ADC0831 is a nice part.
Otherwise, ZN426 could also be used on 5V rail.
The new D/A from Microchip looks interesting (MCP4725).
Sorry, it's not the parallel device you're looking for.
12-bit, op-amp Buffered output, I2C, with EEPROM, SOT23-6.
http://www.microchip.com/stellent/id...cName=en532229
http://news.thomasnet.com/fullstory/536152
So new I'm not sure if you can even get them yet.
Well, except for the 5V requirement, this looks like it might do the job:
http://focus.ti.com/lit/ds/symlink/tlc7226.pdf
Since I need two DACs, this may solve the problem in one package. And I do have an unregulated 16.5 VDC available.
