IF question.
		I have just recently purchased Pic Basic Pro and I am having trouble with a very simple problem. I am programming a 16F84A and I need to monitor one or two inputs to turn on one out put. It's as simple as that. Oddly enough I have had success with other functions such as lcdout but this simple one is stumping me.
Here is my attempt at code:
If Pin0 = 1 Then outpintwo 'call the pin two function
If Pin0 = 1 AND Pin1 = 1 Then outpintwo
Any advice would be appreciated.
Steve Matson
		i don't know how you have declared Pin0, but in PBP you should use variable.. not sure if BasicStamp/PicBasic work with PBP.  anyways..
        MyPushButton VAR PORTB.0
        If MyPushButton = 0 then DoSomething
 HTH
Try this
		'Declare hardware
PinZero   var   portb.0      'push button to ground on this pin
PinOne    var   portb.1      'another pushbutton to ground on this pin
Sig1Out   var   portb.2     ' LED and resistor to show result
Sig2Out   var   portb.3     ' LED and resistor to show result
TRISA = %00000011        ' two inputs 6 outputs
OPTION_REG = %00000000  'turn on weak pullups - PinZero and PinOne will now float high
Loop:
IF PinZero = 0 then Out1   'pinzero has been pulled low by pushbutton pressed
IF (PinZero = 0) AND (PinOne = 0) then Out2
low sig1out
low sig2out
goto loop
Out1:
high sig1out
pause 20
goto loop
Out2:
high sig2out
pause 20
goto loop
HTH
Brian
		Hi Steve Matson,
i had the same issue last night.
The trick is very simple !
You used:
But you need to do:
If (Pin0 = 1) AND (Pin1 = 1) Then outpintwo
The () make all the difference ;)
		Look hard at your logic.
IF PinZero = 0 then Out1 When this is true, you never make it to the 2nd comparison
since Out1 returns you right back to Loop.
If this evaluates as false, then the 2nd comparison will be checked, but then it will always
be false, because PinZero has to be 1 to fall-through to the next comparison.
		code Example:
  if (ThrottleUp=1) then
     if (ThrottleDn=1) then
      if (TrimOK=2) then
       if (AutoRun=1) then
           GoSub EnablePump		'Set required PWM/Timer2 registers
           GoSub EnableGlow
           PumpMath=0
           RunStatus =0
          Evt1 = 0
          goto AutoStart
