Cannot compile for 40MHz 4 x pll
I have a PIC18F2320 and PIC18F242 and would like to run either one @ 40MHz with 4 x pll using a 10MHz crystal.
I cannot get my PBP program to compile.
I am using:
MicroCode Studio Plus V3.0.0.0.
PicBasic Pro 2.47
Asembler = MPASM
The first two lines of my pbp program is:
@ __CONFIG _CONFIG1H, _OSCS_OFF_1H & _HSPLL_OSC_1H
' Oscillator switch OFF
' Use HSPLL (fosc X 4) oscillator (10mhz)
DEFINE OSC 40
If I try to compile my program for the PIC18F2320, I get the following error message:
'Symbol not previously define (_OSCS_OFF_1H)'
If I try to compile my program for the PIC18F242, I get the following error message:
'Overwriting previous address contents'
I noticed that the .inc file for the 18f2320 differs from the .inc file for the 18f242 as follow:
18f2320: __CONFIG _CONFIG1H, _XT_OSC_1H
18f242 : __CONFIG _CONFIG1H, _OSCS_OFF_1H & _XT_OSC_1H
I also tried to change the inc file for the 18f2320 to
but then I get one additional compiler error for the 18f2320.inc file:
Symbol not previously defined (_OSCS_OFF_1H)
Please help!!
Thank you.
