Question about figuring expected battery life based on MAH.
I plan to run some CR2032 cells (3v, about 240 mah cells). These are usually used for very low current drain applications. My application requires a higher drain but short lifespan is probably acceptable - the applicaiton requires as micro-sized batteries as possible.
We'll be running 2 of them in serries to get 6 volts and approx 480 mah combined capacity.
Lets say my circuit draws 20 milliamps of current - can I do the obvious math here and figure an approximate lifespan of about 24 hours?
Someone told me the current from one cell forced through the other cell will cut the effective MAH in half because they are wired in serries. This didn't sound right but who knows.
Also, does the current draw itself impact the mah? For example, maybe it's 240 MAH under a load of .2 milliaps (the example in their data sheet), but when we crank it up 100 times to 20 milliamps, does that mah rating now get smaller because we're sucking the current much faster?
I would assume this would be the case if we draw enough to start generating lots of heat, but even at 20 mA, that shouldn't start smoking the batteries or anything.
Long story short, we're going to draw 20 to 30 mA, and I'd really like to get 15 hours out of a set of batteries if possible. We need at least 10 hours.
