PIC newbie - took ages to program and i still have bugs
Heres the error log
Clean: Deleting intermediary and output files.
Clean: Deleted file "C:\Documents and Settings\\My Documents\speedtemp.mcs".
Clean: Done.
Executing: "C:\Program Files\Microchip\MPASM Suite\MPAsmWin.exe" /q /p16F84 "SPEED254.ASM" /l"SPEED254.lst" /e"SPEED254.err"
Warning[207] C:\DOCUMENTS AND SETTINGS\\MY DOCUMENTS\SPEED254.ASM 140 : Found label after column 1. (SVNSEG) Warning[207] C:\DOCUMENTS AND SETTINGS\\MY DOCUMENTS\SPEED254.ASM 167 : Found label after column 1. (INTER) Error[113] C:\DOCUMENTS AND SETTINGS\\MY DOCUMENTS\SPEED254.ASM 319 : Symbol not previously defined (z) Error[113]
C:\DOCUMENTS AND SETTINGS\\MY DOCUMENTS\SPEED254.ASM 323 : Symbol not previously defined (z) Error[113]
C:\DOCUMENTS AND SETTINGS\\MY DOCUMENTS\SPEED254.ASM 362 : Symbol not previously defined (c) Error[113]
C:\DOCUMENTS AND SETTINGS\\MY DOCUMENTS\SPEED254.ASM 373 : Symbol not previously defined (c) Message[302]
C:\DOCUMENTS AND SETTINGS\\MY DOCUMENTS\SPEED254.ASM 501 : Register in operand not in bank 0. Ensure that bank bits are correct.
Message[302] C:\DOCUMENTS AND SETTINGS\\MY DOCUMENTS\SPEED254.ASM 503 : Register in operand not in bank 0. Ensure that bank bits are correct.
Message[302] C:\DOCUMENTS AND SETTINGS\\MY DOCUMENTS\SPEED254.ASM 505 : Register in operand not in bank 0. Ensure that bank bits are correct.
Message[302] C:\DOCUMENTS AND SETTINGS\\MY DOCUMENTS\SPEED254.ASM 707 : Register in operand not in bank 0. Ensure that bank bits are correct.
Message[302] C:\DOCUMENTS AND SETTINGS\\MY DOCUMENTS\SPEED254.ASM 709 : Register in operand not in bank 0. Ensure that bank bits are correct.
Error[113] C:\DOCUMENTS AND SETTINGS\\MY DOCUMENTS\SPEED254.ASM 729 : Symbol not previously defined (z) Error[113] C:\DOCUMENTS AND SETTINGS\\MY DOCUMENTS\SPEED254.ASM 732 : Symbol not previously defined (z) Message[302] C:\DOCUMENTS AND SETTINGS\\MY DOCUMENTS\SPEED254.ASM 953 : Register in operand not in bank 0. Ensure that bank bits are correct.
Message[302] C:\DOCUMENTS AND SETTINGS\\MY DOCUMENTS\SPEED254.ASM 955 : Register in operand not in bank 0. Ensure that bank bits are correct.
Message[302] C:\DOCUMENTS AND SETTINGS\\MY DOCUMENTS\SPEED254.ASM 957 : Register in operand not in bank 0. Ensure that bank bits are correct.
Message[302] C:\DOCUMENTS AND SETTINGS\\MY DOCUMENTS\SPEED254.ASM 958 : Register in operand not in bank 0. Ensure that bank bits are correct.
Message[302] C:\DOCUMENTS AND SETTINGS\\MY DOCUMENTS\SPEED254.ASM 960 : Register in operand not in bank 0. Ensure that bank bits are correct.
Message[302] C:\DOCUMENTS AND SETTINGS\\MY DOCUMENTS\SPEED254.ASM 961 : Register in operand not in bank 0. Ensure that bank bits are correct.
Message[302] C:\DOCUMENTS AND SETTINGS\\MY DOCUMENTS\SPEED254.ASM 963 : Register in operand not in bank 0. Ensure that bank bits are correct.
Message[302] C:\DOCUMENTS AND SETTINGS\\MY DOCUMENTS\SPEED254.ASM 968 : Register in operand not in bank 0. Ensure that bank bits are correct.
Message[302] C:\DOCUMENTS AND SETTINGS\\MY DOCUMENTS\SPEED254.ASM 970 : Register in operand not in bank 0. Ensure that bank bits are correct.
Error[113] C:\DOCUMENTS AND SETTINGS\\MY DOCUMENTS\SPEED254.ASM 975 : Symbol not previously defined (z) Error[113] C:\DOCUMENTS AND SETTINGS\\MY DOCUMENTS\SPEED254.ASM 1045 : Symbol not previously defined (c) Halting build on first failure as requested.
BUILD FAILED: Tue Sep 25 12:53:21 2007
and my code's attached
Programming language: ASM PIC instruction set
PIC: PIC16F84
Any help would be greatly appreciated
Thanks for the tips so far
btw - I got a build succeeded confirmation - however I have the following error messages.
Clean: Done.
Message[302] C:\PIC LAB\SPEED254.ASM 542 : Register in operand not in bank 0. Ensure that bank bits are correct.
Message[302] C:\PIC LAB\SPEED254.ASM 544 : Register in operand not in bank 0. Ensure that bank bits are correct.
Message[302] C:\PIC LAB\SPEED254.ASM 546 : Register in operand not in bank 0. Ensure that bank bits are correct.
Message[302] C:\PIC LAB\SPEED254.ASM 770 : Register in operand not in bank 0. Ensure that bank bits are correct.
Message[302] C:\PIC LAB\SPEED254.ASM 773 : Register in operand not in bank 0. Ensure that bank bits are correct.
Message[302] C:\PIC LAB\SPEED254.ASM 1049 : Register in operand not in bank 0. Ensure that bank bits are correct.
Message[302] C:\PIC LAB\SPEED254.ASM 1051 : Register in operand not in bank 0. Ensure that bank bits are correct.
Message[302] C:\PIC LAB\SPEED254.ASM 1053 : Register in operand not in bank 0. Ensure that bank bits are correct.
Message[302] C:\PIC LAB\SPEED254.ASM 1054 : Register in operand not in bank 0. Ensure that bank bits are correct.
Message[302] C:\PIC LAB\SPEED254.ASM 1056 : Register in operand not in bank 0. Ensure that bank bits are correct.
Message[302] C:\PIC LAB\SPEED254.ASM 1058 : Register in operand not in bank 0. Ensure that bank bits are correct.
Message[302] C:\PIC LAB\SPEED254.ASM 1060 : Register in operand not in bank 0. Ensure that bank bits are correct.
Message[302] C:\PIC LAB\SPEED254.ASM 1065 : Register in operand not in bank 0. Ensure that bank bits are correct.
Message[302] C:\PIC LAB\SPEED254.ASM 1068 : Register in operand not in bank 0. Ensure that bank bits are correct.
Loaded C:\PIC LAB\SPEED254.cod.
BUILD SUCCEEDED: Wed Sep 26 07:47:42 2007
it seems like the error occurs when accessing eeproms or clearing flags
Does anyone know how to rectify a "Register in operand not in bank 0" error/warning?
