http://www.ladycards.com/blinky/blinkysmall.jpg
I'm so proud to have done this I had to share.
Code:'****************************************************************
'* Name : buckets of grass clippings *
'* Author : Completely plagarized from picbasic.co.uk forums *
'* Notice : Copyright(c) Melanie, Mister e, and others *
'* : All Rights Reserved *
'* Date : 9/19/2007 *
'* Version : 666 *
'* Notes : Magu special in the works! *
' Pic Configuration
' (By Melanie)
' Here we will set the PIC configuration fuses
' to use the internal PIC oscillator and disable the MCLR
' pin.
'@ __CONFIG _INTRC_OSC_NOCLKOUT & _MCLRE_OFF & _LVP_OFF & _WDT_OFF & _PWRTE_ON & _BODEN_ON
' This assume you're using MPASM to compile your code
' For detailed information about Configuration fuse setting,
' have a look to "Presetting Configuration Fuses (PIC Defines)" thread
' in the forum FAQ section.
' http://www.picbasic.co.uk/forum/showthread.php?t=543
' Nomad - went there and stole the correct shtuff for psasm
@ DEVICE pic16F628A, INTRC_OSC_NOCLKOUT
' System Clock Options
@ DEVICE pic16F628A, WDT_ON
' Watchdog Timer
@ DEVICE pic16F628A, PWRT_ON
' Power-On Timer
@ DEVICE pic16F628A, MCLR_OFF
' Master Clear Options (Internal)
@ DEVICE pic16F628A, BOD_ON
' Brown-Out Detect
@ DEVICE pic16F628A, LVP_OFF
' Low-Voltage Programming
@ DEVICE pic16F628A, CPD_OFF
' Data Memory Code Protect
' Set to CPD_OFF for Development Copy
' Set to CPD_ON for Release Copy
@ DEVICE pic16F628A, PROTECT_OFF
' Program Code Protection
' Set to PROTECT_OFF for Development Copy
' Set to PROTECT_ON for Release Copy
' Hardware assignment
GCB_1 VAR PORTB.0
GCB_2 VAR PORTB.1
GCB_3 VAR PORTB.2
' Hardware configuration
TRISB = 0 ' Configure all PORTB i/o to output
' Software/Hardware initialisation
PORTB = 0
' Nomad - bit confused by that bit there
'------------------------------< Main program >-----------------------------------
' by Mister e
Start: '
' Here will do the 'buckets of grass clippings' light show
' using a simple method... not the best
GCB_1 = 1
PAUSE 500
GCB_2 = 1
PAUSE 500
GCB_3 = 1
PAUSE 500
GCB_1 = 0
PAUSE 500
GCB_2 = 0
PAUSE 500
GCB_3 = 0
PAUSE 500
GOTO Start
' Mustard used on brats, find ssubstitute.
' Substituted kidney stones for rocks here but had to remove
' Sorry I had to go!
' Insert Stolen code from T. Jackson and Darrel here
