18F4550 compiles, 18F4620 does not
The following trivial code compiles if I select 18F4550 via the MCS+ 3.0.0.0 drop down box.
I have tried PBPL ver 2.50 and PBPW ver 2.47.
If I select the 18F4620 I get
Error [115] c:\pbp247\pbppi18.lib 1529 : Duplicate label ("DEBUG" or redefining symbol that cannot be redefined)
There are almost identical messages with PBPW and PBPL. Only the c:\...... varies.
Anyone got any ideas?
Cheers
Brian
''* Name : Test 18F4620.PBP *
''* Author : Brian Taylor *
''* Notice : Copyright (c) 2007 Brian Taylor *
''* : All Rights Reserved *
''* Date : 18 SEP 2007 *
''* Version : 4.00 *
''* Notes : *
'' ************************ Defines *****************************
DEFINE osc 4 '
DEFINE Loader_Used 1
DEFINE DEBUG_REG PORTC 'Debug pin port
DEFINE DEBUG_BIT 6 'Debug pin bit
DEFINE DEBUG_BAUD 19200 'Debug baud rate
DEFINE DEBUG_MODE 0 'Debug mode: 0 = True, 1 = Inverted
A var byte
B var byte
ShowRevStatus: ' zzzzz remove in runtime version
pause 50
debug $0D, $0A
for a = 2 to 42
read a,b
debug b
next a
debug $0D, $0A
DEBUG problem with 18F4620
Thank you Bruce and Jeff Schmoyer.
Thank you Jeff for the prompt personal reply.
Bruce's comment above is exactly right and does fix the problem. I must say I usually regard the xxx.inc files as sacred and not to be messed with by amateurs like me.
This is what I did.
I went to c:\mpasm\p18f4620.inc and saved a copy.
I opened c:\mpasm\p18f4620.inc and a couple of pages into the file, at the first instance of the word "DEBUG" I commented out the line with a semi-colon.
OSCCON EQU H'0FD3'
; DEBUG EQU H'0FD4'
T0CON EQU H'0FD5'
Cheers
Brian
