i want send data from 1 pic to other pic using wireless comunication.
i want find the best way to send the data using bluetooth,IR,RF or other divice. can some one help me or give me idea
thank for help
thank for help
IR would probably be the easiest of the methods you've mentioned in my opinion. Another wireless method is ZigBee if you want to look it up.
Your best bet would be to determine which method you would like to use as the first step. Determine how fast you want the communication to be, how much data you are sending, range of the communication etc etc
Cheers
Rob
thank you for reply Rob.
i think i want use bluetooth. because must send data. but i cant find bluetooth module with at command. if use bluetooth module with at command that not to difficult to comunication with PIC.
have some one find bluetooth module with at command and cheap price.
i want control 20 light and range 20 meter.. i can on and off the light using wireless and check the light already on or off.
Rob if u thing using ir more easy can u help me..
Ah, in that case you probably won't want to be using IR! Sorry I can't be of more assistance as I've not designed any bluetooth applications. I think, but not sure, that zigbee was originally designed for lighting control so you may want to check this out first.
There are some people on this forum who have used bluetooth and may be able to help you decide what modules to purchase before you embark on your project. You may want to check out the bluetooth specific section as well.
Good luck
Rob
Hi Po,
Why don't you checkout Bruce's website: www.rentron.com. He has many products and examples on how to do it and he sells the materials! I think this is a good place to start.
HTH,
BobK
