I know there's code out there for voltage measurement using RA0 as input and using the ADC (in my case, on the 16F88) - but it looks like the limit is 5 volts. What can I do to measure larger voltages, say up to 12 volts?
Also, in PBP, the LCD routine likes to use RA0-4 for LCD connections. Since I need to use RA0 as an input, how does one reconfigure the LCD routine to use different pins for the LCD output?
Jeff
