Nokia 3310 display text
I try to doing LCD disply with Nokia 3310 display but not achieve need help.
I used code for this web and change port control, see be low for my code
[code];
;- coder: Alexandros Zahariadis -
;- Thessaloniki- Greece -
;- email: [email protected] -
;PIC61F648A (20Mhz crystal) - 4Mhz is ok,too
'NOKIA 3310 LCD MODULE PINOUT
'as viewed from the back (left -> right)
'1 vcc
'2 sclk portb.7
'3 sda portb.6
'4 d/!c portb.5
'5 !cs portb.4
'6 gnd
'7 Vout
'8 !rst portb.3
INCLUDE "modedefs.bas"
ADCON1 = 7
'defINE OSC 20
defINE OSC 4
CMCON = %00000111 ' Make PortA digital
TRISA = %00000000
TRISB = %00000000
Lcd_CLK var Porta.5
Lcd_SDA var Porta.4
Lcd_DC var Porta.3
Lcd_CS var Porta.2
Lcd_RST var Porta.1
i var Byte
j var Word
k var Byte
b0 var byte
PosX var Byte
PosY var Byte
FontCache var Byte [6]
LcdStr var Byte [26]
Lcd_Data var Byte
Low Lcd_CS 'Chip selected
Gosub Lcd_INIT
Gosub Lcd_Clear
'set contrast
Low Lcd_DC
SHiftOUT Lcd_SDA , Lcd_CLK , MSBFIRST, [ $21,$a7,$20 ]
start:
PosX=0:PosY=0:Gosub Lcd_GotoXY
for i=0 to 13
lookup i,["NOKIA LCD TEST"],j
lcdstr(i)=j
next i
Gosub Lcd_SentString
PosX=0:PosY=1:Gosub Lcd_GotoXY
for i=0 to 13
lookup i,["{} {} {} {} {}"],j
lcdstr(i)=j
next i
PosX=0:PosY=2:Gosub Lcd_GotoXY
for i=0 to 13
lookup i,["{} GRAPHICS {}"],j
lcdstr(i)=j
next i
PosX=0:PosY=3:Gosub Lcd_GotoXY
for i=0 to 13
lookup i,["{} {} {} {} {}"],j 'cars icons!
lcdstr(i)=j
next i
PosX=0:PosY=4:Gosub Lcd_GotoXY
for i=0 to 13
lookup i,["84 X 48 PIXELS"],j
lcdstr(i)=j
next i
PosX=0:PosY=5:Gosub Lcd_GotoXY
for i=0 to 13
lookup i,["ALEX BITMANIAC"],j
lcdstr(i)=j
next i
PAUSE 1000
start2:
'invert screen mode
Low Lcd_DC
Lcd_Data= %00001101:Gosub Lcd_SentByte ;invert
;Lcd_Data= %00001000:Gosub Lcd_SentByte ;blank
'normal screen mode
Low Lcd_DC
Lcd_Data= %00001100:Gosub Lcd_SentByte
pause 3000
;gosub lcd_clear
goto start2
'LCD ROUTINE
Lcd_Init:
'RESET LCD
Low Lcd_RST
pause 20
High Lcd_RST
Low Lcd_CS : Low Lcd_DC
Lcd_Data= $21: Gosub Lcd_SentByte 'LCD EXTENDED COMMANDS
Lcd_Data= $c8: Gosub Lcd_SentByte 'SET LCD Vop (CONTRAST)
Lcd_Data= $06: Gosub Lcd_SentByte 'SET TEMP COEFFICENT
Lcd_Data= $10: Gosub Lcd_SentByte 'LCD BIAS MODE 1:48
Lcd_Data= $20: Gosub Lcd_SentByte 'LCD STANDARD COMMANDS
Lcd_Data= $0c: Gosub Lcd_SentByte 'LCD IN NORMAL MODE
Lcd_SentByte:
SHiftOUT Lcd_SDA , Lcd_CLK , MSBFIRST, [ Lcd_Data ]
Lcd_SentChar:
sELECT CASE lcd_data
CASE 48 '0
j = 156
CASE 49 '1
j = 162
CASE 50 '2
j = 168
CASE 51 '3
j = 174
CASE 52 '4
j = 180
CASE 53 '5
j = 186
CASE 54 '6
j = 192
CASE 55 '7
j = 198
CASE 56 '8
j = 204
CASE 57 '9
j = 210
CASE 32 'space
j = 216
CASE 43 '+
j = 222
CASE 45 '-
j = 228
CASE 46 '.
j = 234
CASE 42 '*
j = 240
CASE 58 ':
j = 246
CASE 124 'character '|' -> graphic!
for i=0 to 5
LOOKUP2 i,[$7e,$95,$a1,$a1,$95,$7e],b0
fontcache(i)=b0:Next i:goto jump
CASE 123 'character '{' -> car half left
for i=0 to 5
LOOKUP2 i,[$18,$5c,$ac,$5e,$1d,$1d],b0
CASE 125
for i=0 to 5 'character '}' -> car half right
LOOKUP2 i,[$1d,$1d,$5f,$ac,$5c,$18],b0
case else 'letters A-Z -capitals
j=(Lcd_Data-65) * 6
end SELECT
For i=0 to 5
READ j+i,fontcache(i)
Next i
jump:
High Lcd_DC
SHiftOUT Lcd_SDA , Lcd_CLK , MSBFIRST, [ FontCache(0),FontCache(1),FontCache(2),FontCache(3 ),FontCache(4),FontCache(5) ]
Lcd_SentString:
For k=0 to 13 ' step -1
Lcd_Data=LcdStr(k)
;If Lcd_Data=0 Then return
pause 80
Gosub Lcd_SentChar
next k
Lcd_Contrast:
Low Lcd_DC
Lcd_Data=$C8:Gosub Lcd_SentByte 'write data
Lcd_Clear:
Gosub Lcd_Home
High Lcd_DC
For i=1 to 252
Lcd_Data=0:Gosub Lcd_SentByte 'write data
Next i
Lcd_Home:
Lcd_GotoXY:
Low Lcd_DC
Lcd_Data=%01000000 | PosY :Gosub Lcd_SentByte 'Y
Lcd_Data=%10000000 | PosX :Gosub Lcd_SentByte 'X
' Font DATA table
Data $7E,$11,$11,$11,$7E,$00 '65 - A - 41
Data $7F,$49,$49,$49,$36,$00 '66 - B - 42
Data $3E,$41,$41,$41,$22,$00 '67 - C - 43
Data $7F,$41,$41,$22,$1C,$00 '68 - D - 44
Data $7F,$49,$49,$49,$41,$00 '69 - E - 45
Data $7F,$09,$09,$09,$01,$00 '70 - F - 46
Data $3E,$41,$49,$49,$7A,$00 '71 - G - 47
Data $7F,$08,$08,$08,$7F,$00 '72 - H - 48
Data $00,$41,$7F,$41,$00,$00 '73 - I - 49
Data $20,$40,$41,$3F,$01,$00 '74 - J - 4A
Data $7F,$08,$14,$22,$41,$00 '75 - K - 4B
Data $7F,$40,$40,$40,$40,$00 '76 - L - 4C
Data $7F,$02,$0C,$02,$7F,$00 '77 - M - 4D
Data $7F,$04,$08,$10,$7F,$00 '78 - N - 4E
Data $3E,$41,$41,$41,$3E,$00 '79 - O - 4F
Data $7F,$09,$09,$09,$06,$00 '80 - P - 50
Data $3E,$41,$51,$21,$5E,$00 '81 - Q - 51
Data $7F,$09,$19,$29,$46,$00 '82 - R - 52
Data $46,$49,$49,$49,$31,$00 '83 - S - 53
Data $01,$01,$7F,$01,$01,$00 '84 - T - 54
Data $3F,$40,$40,$40,$3F,$00 '85 - U - 55
Data $1F,$20,$40,$20,$1F,$00 '86 - V - 56
Data $3F,$40,$38,$40,$3F,$00 '87 - W - 57
Data $63,$14,$08,$14,$63,$00 '88 - X - 58
Data $07,$08,$70,$08,$07,$00 '89 - Y - 59
Data $61,$51,$49,$45,$43,$00 '90 - Z - 5A
Data $3E,$51,$49,$45,$3E,$00 '48 - 0 - 30
Data $00,$42,$7F,$40,$00,$00 '49 - 1 - 31
Data $42,$61,$51,$49,$46,$00 '50 - 2 - 32
Data $21,$41,$45,$4B,$31,$00 '51 - 3 - 33
Data $18,$14,$12,$7F,$10,$00 '52 - 4 - 34
Data $27,$45,$45,$45,$39,$00 '53 - 5 - 35
Data $3C,$4A,$49,$49,$30,$00 '54 - 6 - 36
Data $01,$71,$09,$05,$03,$00 '55 - 7 - 37
Data $36,$49,$49,$49,$36,$00 '56 - 8 - 38
Data $06,$49,$49,$49,$3E,$00 '57 - 9 - 39
Data $00,$00,$00,$00,$00,$00 '32 - - 20
Data $08,$08,$3E,$08,$08,$00 '43 - + - 2B
Data $08,$08,$08,$08,$08,$00 '45 - - - 2D
Data $00,$60,$60,$00,$00,$00 '46 - . - 2E
Data $14,$08,$3E,$08,$14,$00 '42 - * - 2A
Data $00,$36,$36,$00,$00,$00 '58 - : - 3A
