Timing verification.
Hello folks,
I would like to have a quick verifcation on a program, or is it me missing a link in my head?
The following program uses a pauseus statement
If I use Pauseus 1, it has 28 micosecond delay between spikes.
If I use Pauseus 5, it has 28 Microsecond delay between spikes.
If I use Pauseus 3, it has 30 Microsecond delay between spikes.
If I use Pauseus 10, It has a 28 Microsecond delay between spikes.
If I use a PAUSE 1 it has a 1 millisecond delay (which is good)
I probably have a screw loose upstairs that is baffling me on this situaion, and I have not figured it out yet.
Here is the complete code to simulate this senario:
@ DEVICE PIC12F675,INTRC_OSC_NOCLKOUT,WDT_ON,PWRT_OFF,BOD_O N,PROTECT_OFF,CPD_OFF,MCLR_OFF
CMCON=%00001000
TRISIO=%00000000
Loop:
GPIO=%00000001
GPIO=%00000000
pauseus 1 'replace this with the numbers mentioned above
GOTO Loop
Hi Dwayne -
I would guess it might be related to resolution. The pbp manual says thet the minimum delay for lets say a 4 MHz resonator to your pic is about 24 micro seconds....so when you ask for less...you are asking for too short of a pause....switching to a 20 MHz resonator should increase your resolution down to 3 micro seconds.
Best Regards,
Carl
PIC Development Boards with bootloader
www.schellelectronics.com
Novi, Michigan, USA
@ NOP
Insert for 1uS Delay at 4MHz, 500nS delay at 8MHz etc etc.
Hello Carl and Melanie,
Carl>>I would guess it might be related to resolution. The pbp manual says thet the minimum delay for lets say a 4 MHz resonator to your pic is about 24 micro seconds....so when you ask for less...you are asking for too short of a pause....switching to a 20 MHz resonator should increase your resolution down to 3 micro seconds. <<
Thanks a million both of you. I guess I was assuming too much <g>. I knew there had to be something going on... I was up too late last night working on a stupid project... thank goodness there is not a time limit. <g>
Dwayne
