hello everyone,
i am new in picbasic pro,recently i work on a project <touch switch dimmer>
i make 9 switches and connect them into pic 16f876,each output of the switch will give 0v or 5v.
1 switch is connected in portc.6 act as a selection button, when i touch it once,it control my LED brightness
second touch will goes to control my servo motor's speed
i arrange the rest of the 8 switches in circular shape and their output is connected to port B of my pic as a intensity controller. when i move clockwise, it will increase the brightness of the LED or the speed of the motor (depend on which 1 selected). If i move counter-clockwise,it will decrease the intensity.
and my output is pin CCP1 and CCP2,the output is connected to a RC filter then to the transistor and control the LED or the Motor circuit.
In this project, i try to use pwm to control the intensity,i need some idea to write the code...
before this,i try a code as below to test the pwm output,but it seem not work:
' Output is a 1Khz signal with duty cycle sweeping
' from 20% to 80% once per second
' Note: PWM output will be on the CCP1 pin. Register
' names are for the PIC16F87x devices.
' PR2 = Timer2 period register, controls PWM period.
' CCPR1L and CCP1CON<5:4>bits control the duty cycle,
' and should be treated as a 10-bit word
' Fosc = Clock Frequency (4MHz)
' PS = Timer2 Prescale Value (T2CON<1:0>)
' Freq = PWM output frequency
' Duty% = Duty cycle (20% = 0.2)
' formulas:
' PR2=(Fosc/(4*PS*Freq))-1
' CCPR1L:CCP1CON<5:4>=(PR2+1)*4*Duty%
duty VAR WORD ' Duty cycle value (CCPR1L:CCP1CON<5:4>)
TRISC.2 = 0 ' Set PORTC.2 (CCP1) to output
CCP1CON = %00001100 ' Set CCP1 to PWM
T2CON = %00000101 ' Turn on Timer2, Prescale=4
' Use formula to determine PR2 value for a 1KHz signal,
' 4MHz clock, and prescale=4. (4E6/(4*4*1E3))-1=249
PR2 = 249 ' Set PR2 to get 1KHz out
' Use formula to determine CCPR1L:CCP1CON<5:4> value for
' ends of range 20% to 80%. (249+1)*4*0.2=200 (20% value)
' (249+1)*4*0.8=800 (80% value)
duty = 200 ' Set duty cycle to 20%
loop: CCP1CON.4 = duty.0 ' Store duty to registers as
CCP1CON.5 = duty.1 ' a 10-bit word
CCPR1L = DUTY >> 2
duty = duty + 10 ' Increase duty cycle
' Since the total sweep of duty is 600 (800-200) and
' we are adding 10 for each loop, that results in 60
' steps min to max. 1 second divided by 60 = 16.67mS
Pause 17 ' Pause 1/60 of second
IF (duty < 800) Then loop ' Do it again unless 80% duty cycle
duty = 200 ' Reset to 20% duty cycle
GoTo loop ' Do it forever
thank for your helps
