ASM equiv for SERIN2???
I think I need to speed up my program by using ASM.
Basically I have a PIC programmed as a DCE using Hardware flow control, it then prints out to a centronics printer.
My flow control (Using DSR and CTS) from the PIC works ok but when the flow speed is increased, the PIC fails to print some characters...
Here is a cut from the code: (CTS - Clear to Send)
MAIN:
HIGH CTS
SERIN2 SDI,16780,[char]
LOW CTS
<... output to printer here ....>
GOTO MAIN
It seems that the pic is not quick enough between capturing the char and clearing the CTS signal.
I may be able to speed things up by converting the above three lines to ASM?
Can anybody help please?
J
Hello Squibcakes,
First, avoid the commands: High <pin> and LOW <pin>.
Use CTS=1 or CTS=0 instead. The take less code space and I thing they execute faster. There is an assembly equivalent of just few lines but I do not use assemble and need to read the manual to answer this.
Secondly, you might try the HSERIN and HSEROUT commands if your PIC has a hardware USART build-in. This might need a MAX232 IC to invert the logic.
K.
Hi Kypros,
Thanks for the HIGH / LOW tip...
I've been playing around with the code some more and found that it is even better to use the FLOW pin option.. ie
SERIN2 SDI\FLOW,16780,[char]
and scrap the HIGH , LOW flow commands all together.
Its possible that the PC's UART buffe is still causing me some problems and headaches....
I may need to re wire and use the USART after all.... I will post here if I have any success.
Squib
