hi every one. i am fresh here. i got a problem with coding about arrays.
what i wanted to do is to create an array which have a series of constants that i won't be changing during runtime.
i believe there is a code which is like " a var byte[10] " is possible but this required the pic's ram and the ram is pretty limited. so, can i create the array as in constant or as code which i can den use later on?
futher more, how to put in data in array mode? which some thing like " a[] = {1 2 3 4 5 6 7} "
thank you
