looking for pointers, tips, etc...
Hello all,
What an adventure this has been! I have completely fallen for this enbedded coding stuff and in paticular PBP. Best money I have spent in a long time. More fun then I have had in a long time...I actully like my job again!
Here is my little project so far...Just the keyboard scan part. Now I know of Mr._E's Keypad.bas include. But I wanted to write my own for educational purposes...
Here is my code...I should mention that the the 3x4 keypad is NOT a standard keypad its custom made for my company. So ignore that there is not "#" or "*"
Also, it is a neccessary for me to get the keypressed one at a time. This is so we can compare the entered code number by number and compare it to the stored number. Rather then using an array or for/next to gather a group of keypresses.
@ DEVICE HS_OSC
'SET OSC BIT TO HS
'Defines...
'*lcd defines*
DEFINE LCD_DREG PORTD 'Define PIC port used for LCD Data lines
DEFINE LCD_DBIT 4 'Define first pin of portd connected to LCD DB4
DEFINE LCD_RSREG PORTD 'Define PIC port used for RS line of LCD
DEFINE LCD_RSBIT 2 'Define Portd pin used for RS connection
DEFINE LCD_EREG PORTD 'Define PIC port used for E line of LCD
DEFINE LCD_EBIT 3 'Define Portd pin used for E connection
DEFINE LCD_BITS 4 'Define the 4 bit communication mode to LCD
DEFINE LCD_LINES 2 'Define using a 2 line LCD
DEFINE LCD_COMMANDUS 2000 'Define delay time between sending LCD commands
DEFINE LCD_DATAUS 50 'Define delay time between data sent.
'*other defines*
DEFINE OSC 8 'DEFINE EXTERNAL OCS TO 8MHZ
'setup ports...
INIT:
'TRISC = %00000000 'SETS PORTC TO ALL OUTPUTS (future use)
'PORTC = %00000000 'TURNS ALL OF PORT C OFF (future use)
'OPTION_REG.7=0 'Enable the internal PORTB pullups (this does nt wk)
TRISB = %00001111 'Set Keypad I/O 1=input 0=output
PORTB = 0 'Set columns LOW
'setup variables...
key var byte
lcdout $fe, 1 ' Clear LCD
main: 'SCAN keypad for key press
colum0:
portb = %00010000 'turn on colum0 for row scan
if portb.1 = 1 then key = 9: goto display
if portb.2 = 1 then key = 6: goto display
if portb.3 = 1 then key = 3: goto display
colum1:
portb = %00100000 'turn on colum1 for row scan
if portb.0 = 1 then key = 0: goto display
if portb.1 = 1 then key = 8: goto display
if portb.2 = 1 then key = 5: goto display
if portb.3 = 1 then key = 2: goto display
colum2:
portb = %01000000 'turn on colum2 for row scan
if portb.1 = 1 then key = 7: goto display
if portb.2 = 1 then key = 4: goto display
if portb.3 = 1 then key = 1: goto display
DISPLAY:
' LCD Command codes
' $01 Clear Display
' $02 home
' $0C Cursor off
' $0E Underline cursor on
' $0F Blinking cursor on
' $10 Move cursor left one character
' $14 Move cursor right one character
' $C0 Move cursor to begining of next line
' all commands must use the format LCDOUT $fe, XX
'Setup LCD...
lcdout $fe, 2 ' Position cursor at home
lcdout "you pressed..", dec key
Everything works just fine. I am now trying to figure out a good way to debounce. But for now I would love to hear from some of you more advance coders as to how I could make this...Well....more eligante. I looked at the "lookup" command and many examples. I just cant seem to get my head wrapped around how I would impliment it. So if your idea has anything to do with that please include a small tutorial on lookup tables.
I should also mention that this is just test code. I have broken down my project into several steps. I am making one step work then moving on to the next. Eventually, I will have the knowledge to pull them all together. For example, I figured out the LCD stuff....Moved on to the Scanning of the keypad....Next is reading and writing to the internal EEPROM...etc...
Oh...I am using the following apps and chips just as a reference....
PIC16f877a
EasyPIC4 Dev. board (mikroelektronika)
PBP 4.27
PICFlash 4.07 (mikro again)
pm.exe compiler
Your thoughts please ladies and gentlemen...
Best regards,
Bill12780
