USART Problem , but don't know where, in pc? or in PIC?
When i connect hyperterminal to PIC , Rs232 reception is good like +00000 .but when i disconnect to termibal and then connect again,
Hyper terminal received junk data, problem fixed after reset PIC.
Problem is reset required every time when connect terminal.
I tried on dif. Xtal osc and dif. code from mister_e's calculator.
'chipi8f4550
'configuration of osc - '@ __CONFIG _CONFIG1H, _FOSC_HSPLL_HS_1H
define osc 48 ; actual xtal mount 20mhz
DEFINE HSER_SPBRG 8 ' 9600 Baud @ 20MHz, -0.03%
SPBRGH = 2
BAUDCON.3 = 1 ' Enable 16 bit baudrate generator
HSerout [ss,dec5 ABS(LastW0),13,10]
baud rate is 38400 in this position - no problem , no reset require
'chipi8f4550
define osc 48 ' actual xtal 20
DEFINE HSER_SPBRG 225 ' 9600 Baud @ 48MHz, 0.0%
SPBRGH = 4
baud rate is 9600 in this position - reset require ( problem )
chip 18f4550
'configuration of osc HS
DEFINE OSC 10 ;actual xtal mount 11.0592
DEFINE HSER_SPBRG 71 ' 9600 Baud @ 11.0592MHz, 0.0%
SPBRGH = 0
baud rate is 9600 in this position - no problem , no reset require
baud 19200 if i mount xtal 21.47727 in same code -- no problem , no reset require
but my requirment is
define osc 48
xtal - 20mhz
baudrate 9600
