High Voltage Danger? When?
Hi.
I am building a coilgun with some capacitors, and I would like to use a PIC handle the charging process. I read that gigh voltage capacitors are dangeroud, but what is it that makes electricity dangerous? If you were to pu 10 or 15 9-volt-batteries in series, and touch the contacts, would it shock you? Is it safe to build a capacitor bank (about 47000uf) at 25vdc?
What is the difference (speaking about dangers) betweeb DC and AC?
Thanks in advance!!!!
Manuel
How much electricity will kill me?
This is an often asked question. How many Volts? How many Amps? To answer this we need to look at kinds of damage an electric current can cause.
The first and least likely one is tissue damage as a result of burning. Ignoring other electrical effects such as microwave cooking and high frequency transmitter outputs, and looking just at direct electrical contact, burning damage is only likely from very high voltage sources in excess of 1000V for example Eskom power lines and Transnet overhead rail power systems, and as we are not likely to come into contact with these, we will just look at mains borne 220V/380V systems.
This leaves us the most likely cause of death which is the failure of the heart muscle through fibrillation and this will occur when a (generally accepted) current of between 60mA and 1A passes through the heart. The heart's electrical system gets disrupted and it stops pumping. So you might say it's the current that kills you, but wait, to get such a current to pass through the heart we have to satisfy Ohm's law which tells us that to get a current through a resistance (the body and skin resistance) we need a certain voltage. (current = voltage ÷ resistance).
This leads us to the source of the variability: What is the resistance of the body?
If you were to stick a drip needle in each arm and measure the resistance between them, you could get a resistance of as little as 500Ω. To get a current of 60mA to pass through this you would need only 30V! This is why electro-medical equipment has to be so carefully designed. Your skin resistance varies greatly with the dampness, sweat and salinity, and can vary from 1000Ω to 30,000 Ω.
At 1000Ω you would need a voltage of only 60V to be lethal, on the other hand with very dry clean skin at 30,000Ω a voltage of 220V would only produce a tingling 7mA and this is why many folks have had shocks which did them no harm. So at 220V you need a body resistance less than 3700Ω to kill you. Of more concern at higher voltages greater than 500V, skin puncturing can occur, causing a now much lower resistance and potential fatalities.
So we can now answer the question "Is it the current or is it the voltage that kills you?"
Certainly it is the current, but for it to reach a lethal level we need the voltage to drive it. To be safe, treat anything over 24V with caution, and anything over 50V with a great deal of respect. Anything over 100V is certainly able to kill you.
Graham Lambert
