Hello All,
I need i little help with timer1 in 16F688. I am trying to set the interrupt to flag at about 60us. I have the pic running on the internal oscillator at 8Mhz but for some odd reason it interrupts at far greater than 100ms. I was able to get TMR0 to interrupt as low as 250us but could not get it lower than that. since TMR1 is 16 bits i figured that i will be able to get it lower. Yes i used the PICmulticalc, and according to that I sould get it to interrupt at 65us at 8Mhz. Here is some code to what i am trying to do.
basically i have another pic that is sending a constant pulse which i can vary. th16f688 has an onchange interrupt and every OCI it reinitializes the timer. basically i want the pic to time out when a pulse is larger than 65us(approx)
appearantly the timer times out but i have to put a pulse of something greater than 100ms. any help is appreciated thank you. jose
DEFINE OSC 8
TRISA = %111111 'PORTA as input
TRISC = %000000 'PORTC as output
ANSEL = 0
CMCON0 = 7
'Set to 8 Mhz
OSCCON.4 = 1 'Int Osc = 8MHZ
OSCCON.5 = 1 'Int Osc = 8MHZ
OSCCON.6 = 1 'Int Osc = 8MHZ
'Enable Interrupt Register
INTCON.3 = 1 'PORTA change interupt enabled
INTCON.6 = 1 'Enables Peripheral interrupt
INTCON.7 = 1 'Global interrupt enabled
PIE1.0 = 1 ' Enables the Timer1 Overflow interrupt
'Enable Timer1 Register
T1CON.0 = 1 'Enables Timer1
T1CON.1 = 0 'Internal Clock
T1CON.3 = 0 'LP oscillator is off
T1CON.4 = 0 '1:1 prescaler
T1CON.5 = 0 '1:1 prescaler
T1CON.6 = 0 'TMR1 is on
IOCA.0 = 1 'PORTA.0 is an OCI
OPTION_REG.7 = 0 'Enable Pullup Resistors
'=======Flag Bits======
'PIR1.0 = 1 ' TMR1F Flag Enabled
'PIR1.0 = 0 ' TMR1F Flag Disabled
'INTCON.0 = 1 ' IOC Interrupt Flag enabled
'INTCON.0 = 0 ' Interrupt Flag disabled
on interrupt GOTO myInterrupt
LED VAR PORTC.0
LED1 VAR PORTC.1
dummy VAR PORTC.2
LOW LED
LOW LED1
HIGH dummy
LOW dummy
disable
myInterrupt:
if PIR1.0 = 1 then timerInt
if INTCON.0 = 1 then onchangeInt
resume
timerInt:
HIGH LED1
LOW LED1
TMR1H = 0
TMR1L = 0
PIR1.0 = 0 'remove interrupt flag
resume
onchangeINT:
TMR1H = 0
TMR1L = 0
INTCON.0 = 0
resume
