LED blinking ( again )
I just got a 18F4431 from a friend.
I tried to make led blink, with following code , but the only LED that turn on/off is the LED on RB0, why ?
OSCCON = $60 ' Internal oscillator frequency 4 Mhz
TRISB = %00000000 ' Set PORTB to all output
TRISC = %00000000 ' Set PORTC to all input
TRISD = %00000000 ' Set PORTD to all output
TRISE = %00000000 ' Set PORTE to all output
ANSEL0= %00000000 ' Analog channel AN0-AN7 off
ANSEL1= %00000000 ' Analog channel AN8 off
PORTA = 0
PORTB = 0
PORTC = 0
PORTD = 0
PORTE = 0
CLear
high PORTB
LOW PORTB
HIGH PORTC
LOW PORTC
high PORTD
low PORTD
high PORTE
LOW PORTE
HIGH & LOW work with a "pin". Not a whole port. Try PORTB = %01010101 or
some other 8-bit value to write to all 8-bits of a port at once.
If using HIGH or LOW, then use a port 'bit' like HIGH PORTB.0, PORTB.1, etc.
Thank you Bruce,
Yes, now it works :)
I am a beginner with PBP,and I learn fast by making mistakes :)
Now I will try to put some character on LCD
