Hi Guys, Does any one know or have a sample code controlling RTL8019AS
using PicBasic pro "pbp"? Thank you very much for your help
I haven't seen any PBP code but there is some BASCOM-AVR code for EDTP's Packet Whacker (RTL8019AS based) at http://members.home.nl/bzijlstra/sof...ples/basex.htm which you might be able to port to PBP.
If you are not locked in to the RTL8019AS you might want to follow the PIC18F67J60 thread in this forum. I think it will prove more fruitful for PBP users.
I was Planning to Interface P16f877 to RTl8019AS , using pbp picbasic pro compiler and coding in PBP , do you have any Idea of it? thanks
Based on other forums, UDP mode is mostly possible, but any mode will do
as long I can hook up PIC to LAN so that I can NETWORK all PIC's any sample codes for pbp pro?
