		Serial coms with a pc
		Hi there
 I have built a circuit with a pic16f627 and a so232acp chip. The idea is to read an input and display it on hyper terminal and toggle two leds if I send a command from the pc, I am using the on board usart.
 The transmitting from the pic work 100% but I can not seem to get it responding to the commands from the pc. Can anyone please help; here is the testing code I use.
 INCLUDE  "ANSI.INC"
 CMCON = %00000111  		;Disable Comparator module's
 OPTION_REG = %11010111               ;Set PIC options
 INTCON = 0  			;Disable interrupts
 TRISB = %00000000 		;RB7...RB0 are outputs.
 TRISA = 255				;SET PORTA AS INPUTS
 DEFINE HSER_RCSTA 90h	;Set receive register to receiver enabled
 DEFINE HSER_TXSTA 20h	;Set transmit regester to transmitter enabled
 DEFINE HSER_BAUD 2400	;Set baud rate
 DEFINE HSER_SPBRG 25	;Set spbrg regester
 I	VAR BYTE
 I = 0
 PORTB.6 = 1
 loop:
 I =0
 @ ClearScr         ; Clear Screen
 HSEROUT ["Value of input 1:",DEC PORTA.0,10,13]
 HSEROUT ["Please select a command",10,13]
 HSEROUT [9,"1 = Flash leds",10,13]
 HSERIN 5000,LOOP,[I]
 IF I = 1 THEN
 PORTB.7 = 1
 PORTB.6 = 0
 PAUSE 1000
 PORTB.7 = 0
 PORTB.6 = 1
 GOTO LOOP
 GOTO LOOP
		Try checking for the condition
 If i = "1" then
 since the keypressed from the pc is a printable ascii character.
 Jerson
 INCLUDE  "ANSI.INC"
 cmcon=7:option_reg=$d7:intcon=0:trisb=0:trisa=$ff
 temp var byte:I VAR BYTE:I = 0
 loop:
 I =0
 hserout ["Value of input 1:",dec porta.0,10,13]
 hserout ["Please select a command",10,13]
 hserout [9,"1 = Flash 1 LED",10,13]:hserout [9,"2 = Flash 2 LED",10,13]
 hserout [9,"3 = Flash Both LED",10,13]:hserin 5000,loop,[I]
 IF I = "1" THEN
 for temp = 1 to 10:PORTB.7 = 1:pause 1000:portb.7=0:pause 1000:next temp
 if i = "2" then
 for temp = 1 to 10:portb.6=1:pause 1000:portb.6=0:pause 1000:next temp
 if i="3" then
 for temp = 1 to 10:portb.6=1:portb.7=1:pause 1000:portb.6=0
 GOTO LOOP
 Try that out...
 EDIT:  DOH!  Jerson beat me to it! :)
		Thank you for the reply, but stil nothing.
 I am starting to think my hardware is faulty. I have written a program that acording to me could ecco what is sended to the pic. do you agree with the program, if it is correct i definitly need to start looking at my hardware.
 Thank you again for al the help
 INCLUDE  "ANSI.INC"
 I	VAR BYTE
 I = 20
 loop:
 HSEROUT ["Value of I:",I,10,13]
 GOTO loop
		Loopback with lower case to upper case translation (shows the PIC is actually working and that the PC isn't just receiving the same thing it sent out, i.e. local echo):
 include "modedefs.bas"
 cmcon=7:option_reg=$d7:trisb=0:trisa=$ff:i var byte
 serin portb.1,n2400,I:if (i > 96) and (i < 123) then i = i - 32
 serout portb.2,n2400,[I]:goto main
 And I just noticed something in the code in your last post.  Take out the clear screen and if anything happens...
		i just copy/paste your code and, yes indeed there's few mistake.
 first..
 In red, you overwrite PBP calcs.  This result of a bad SPBRG setting for a TXSTA=20.  Also, as you're using HSERIN, i would suggest you to use HSER_CLROERR feature to clear all possible overflow error.  The correct declaration should be
 DEFINE HSER_SPBRG 25  ' 9600 Baud @ 4MHz, 0.16%
 Even with this, you have configure the RX pin as output :eek:  so change TRISB to
 TRISB = %00000010 ' RB1(RX) as input, others to Output
 that sort few error, but unless you want to have a full-filled of "Value of I:" screen, i'll suggest you to remove the timeout delay and it's jump label
 This way, the program will sit there and wait for a user entry.
 <hr>
 EVEN with the above correction done, you may have some problem if you're using the internal OSC, if your "Value of I" message is messy, use an external one OR try with a lower baudrate.  Here, it doesn't work @9600 baud with the internal OSC.  The output looks like
 i don't know for others... but i can't understand what the above ask me ;)
 <hr>
 the full corrected code, with config fuse setting for MPASM and a external 4MHz crystal, but without the ANSI feature looks like
 <font color="#000000">    <font color="#008000">;INCLUDE "ANSI.INC"
 </font>@ __CONFIG _XT_OSC  & _MCLRE_ON  &  _LVP_OFF & _WDT_OFF & _PWRTE_ON  & _BODEN_ON
 CMCON = %00000111 <font color="#008000">;Disable Comparator module's
 </font>OPTION_REG = %11010111 <font color="#008000">;Set PIC options
 </font>INTCON = 0 <font color="#008000">;Disable interrupts
 </font>TRISB = %00000010 <font color="#008000">' RB1(RX) as input, others to Output
 </font>TRISA = 255 <font color="#008000">;SET PORTA AS INPUTS
 </font><font color="#000080">DEFINE </font>HSER_RCSTA 90h <font color="#008000">' Enable serial port & continuous receive
 </font><font color="#000080">DEFINE </font>HSER_TXSTA 24h <font color="#008000">' Enable transmit, BRGH = 1
 </font><font color="#000080">DEFINE </font>HSER_SPBRG 25  <font color="#008000">' 9600 Baud @ 4MHz, 0.16%
 </font><font color="#000080">DEFINE </font>HSER_CLROERR 1 <font color="#008000">' Clear overflow automatically
 </font>I <font color="#000080">VAR BYTE
 </font>I = 20
 loop:
 <font color="#008000">;@ ClearScr ; Clear Screen
 </font><font color="#000080">HSEROUT </font>["Value of I:",I,10,13]
 <font color="#000080">HSERIN </font>[I]
 <font color="#000080">GOTO </font>loop
 <font color="#000080">END
 </font>
 More information on config fuse and possible compilation warning messages at the following link
 hth
		Well, I'm always looking for "comments" on my programs.
 I guess "commenting" them out qualifies. :)
 ANSI.INC
		:D don't take it personal.. i hate Hyperterminal, sure it has to work with.
		And the best part is ... you don't have to use Hyperterminal.
 Any terminal program that can emulate ANSI will do.
 Even a DOS window with ANSI.SYS loaded. Yuck!
		Deuh... but MisteEZCOM one don't do it :D
 Anyhow, proof it's working...
 <IMG SRC="http://www.picbasic.co.uk/forum/attachment.php?attachmentid=1754&stc=1&d=118211864  3">
 I prefer RealTerm... but... erm, MisterEZCOM is not bad to...
     @ ForColor yellow               ; Set foreground (text) color to yellow
 @ BackColor blue                ; Set background color to blue
 loop:
 HSERIN [i]
 GOTO loop
 Feel better now ? http://www.mister-e.org/Pics/ROFL
		Well yes, actually, I do. :)
 Thank you!
		P.S.
 Where do I get this MisterEZCOM?
 Must have missed that thread.
		It's not released yet, so you didn't missed it ;)
