12F629 Strange interupt behavior
Below is my code. What I dam doing is controlling a camera. Initially I have 1 button that sets a variable from 1 to 3. Under each variable I set certain functions. Under #1 I set delays between pictures, under #2 I set 24hour, day only, or night only pictures. Under #3 I set standard camera mode, double picture mode or video mode. GPIO.1 sets the 3 variables and GPIO.3 sets the stuff under each variable. An led blinks a corresponding number of times for these. GPIO.0 triggers the pic to take pictures.
The problem I am having is in the routine that determines if it should take a picture if its day or night. In either case the led starts blinking and it increments the variables. If it is set to 24 hour it works fine. If someone could take a look and possibly see anything that would cause this I'd appreciate it. I've about pulled all my hair out. BTW, some labeling is wrong, ignore it.
@ DEVICE pic12F629, INTRC_OSC_NOCLKOUT ; System Clock Options
@ DEVICE pic12F629, WDT_ON ; Watchdog Timer
@ DEVICE pic12F629, PWRT_ON ; Power-On Timer
@ DEVICE pic12F629, MCLR_OFF ; Master Clear Options (Internal)
@ DEVICE pic12F629, BOD_OFF ; Brown-Out Detect
@ DEVICE pic12F629, CPD_ON ; Data Memory Code Protect
@ DEVICE pic12F629, PROTECT_OFF
; Set Variables and aliases as needed.
symbol TRIG = GPIO.0
SYMBOL CAMPOW = GPIO.4
SYMBOL CAMSHUT = GPIO.5
GPIO0NEW VAR BYTE
GPIOOOLD VAR BYTE
GPIO1NEW VAR BYTE
GPIO1OLD VAR BYTE
GPIO3NEW VAR BYTE
GPIO3OLD VAR BYTE
I VAR BYTE
J VAR BYTE
K VAR BYTE
L VAR BYTE
M VAR BYTE
N VAR BYTE
O VAR BYTE
P VAR BYTE
Q VAR BYTE
OUTPUT GPIO.2
HIGH GPIO.2
TRISIO = %00001011
OPTION_REG = %00001000;
WPU = 00001011
CMCON = 7 ;
INTCON = %10000000 ; Set GIE - clear interrupt enable bit and flags.
IOCB = %00001011
low CAMPOW
LOW CAMSHUT
J = 0
i = 0
M = 0
K = 0
L = 0
N = 0
O = 0
P = 0
PAUSE 20000
low GPIO.2
PAUSE 500
HIGH GPIO.2
GOTO BASE
MYINT:
GPIO0NEW = GPIO.0
GPIO1NEW = GPIO.1
GPIO3NEW = GPIO.3
IF GPIO0NEW <> GPIOOOLD THEN
Q = 1
GOTO CAM
IF GPIO1NEW <> GPIO1OLD THEN
L=1
M = 1 + M
IF M > 3 THEN
M = 1
FOR i = 1 TO M
LOW GPIO.2
PAUSE 200
HIGH GPIO.2
PAUSE 200
NEXT I
GPIO1OLD = GPIO.1
GPIO3OLD = GPIO.3
GPIOOOLD = GPIO.0
RESUME BASE
IF GPIO3NEW <> GPIO3OLD THEN
j = 1
IF M = 1 THEN
GOTO DELAYS
IF M = 2 THEN
GOTO DNB
IF M = 3 THEN
GOTO CMODE
DELAYS:
K = K + 1
IF K = 6 THEN
K = 1
FOR i = 1 TO K
LOW GPIO.2
PAUSE 500
HIGH GPIO.2
PAUSE 500
NEXT I
IF K = 1 THEN
N = 1
IF K = 2 THEN
N = 25
IF K = 3 THEN
N = 51
IF K = 4 THEN
N = 257
IF K = 5 THEN
N = 1029
GPIO3OLD = GPIO.3
GPIO1OLD = GPIO.1
GPIOOOLD = GPIO.0
RESUME BASE
DNB:
K = K + 1
IF K > 3 THEN
K = 1
FOR i = 1 TO K
LOW GPIO.2
PAUSE 500
HIGH GPIO.2
PAUSE 500
NEXT I
O = K
GPIO3OLD = GPIO.3
GPIO1OLD = GPIO.1
GPIOOOLD = GPIO.0
RESUME BASE
CMODE:
K = K + 1
IF K > 3 THEN
K = 1
FOR i = 1 TO K
LOW GPIO.2
PAUSE 500
HIGH GPIO.2
PAUSE 500
NEXT I
P = K
GPIO3OLD = GPIO.3
GPIO1OLD = GPIO.1
GPIOOOLD = GPIO.0
RESUME BASE
CAM:
INPUT GPIO.2
WPU = 00001111
IF O = 2 AND GPIO.2 = 1 THEN
OUTPUT GPIO.2
WPU = 00001011
GPIO3OLD = GPIO.3
GPIO1OLD = GPIO.1
GPIOOOLD = GPIO.0
RESUME BASE
IF O = 3 AND GPIO.2 = 0 THEN
OUTPUT GPIO.2
WPU = 00001011
GPIO3OLD = GPIO.3
GPIO1OLD = GPIO.1
GPIOOOLD = GPIO.0
RESUME BASE
OUTPUT GPIO.2
WPU = 00001011
IF P = 1 THEN
GOTO SCAMR
IF P = 2 THEN
GOTO DPM
IF P = 3 THEN
GOTO MOVMODE
SCAMR:
HIGH CAMPOW 'PRESS POWER
PAUSE 500 'HOLD POWER FOR 500 MILLISECOND
LOW CAMPOW 'RELEASE POWER
pause 2200
HIGH CAMSHUT 'PRESS SHUTTER FOR 2 SECOND
PAUSE 3000
LOW CAMSHUT 'RELEASE SHUTTER
PAUSE 8000 'ALLOW 8 MORE SECONDS TO SAVE AND TURN CAMERA OFF
HIGH CAMPOW 'TURN CAMERA OFF
PAUSE 500
LOW CAMPOW
GPIOOOLD = GPIO.0
GPIO3OLD = GPIO.3
GPIO1OLD = GPIO.1
RESUME BASE
DPM:
pause 2200
PAUSE 3000
PAUSE 6000 'ALLOW 8 MORE SECONDS TO SAVE AND TURN CAMERA OFF
HIGH CAMSHUT 'TURN CAMERA OFF
PAUSE 500
LOW CAMSHUT
PAUSE 500
LOW CAMPOW
GPIOOOLD = GPIO.0
GPIO3OLD = GPIO.3
GPIO1OLD = GPIO.1
RESUME BASE
MOVMODE:
pause 2200
PAUSE 3000
PAUSE 17000 'ALLOW 8 MORE SECONDS TO SAVE AND TURN CAMERA OFF
PAUSE 500
LOW CAMSHUT
PAUSE 500
LOW CAMPOW
GPIOOOLD = GPIO.0
GPIO3OLD = GPIO.3
GPIO1OLD = GPIO.1
RESUME BASE
REFRESH:
PAUSE 5000
GOTO LOOP
BASE:
IF J = 1 THEN
WRITE 1,K
WRITE 3,N
WRITE 4,O
WRITE 5,P
IF L = 1 THEN
WRITE 2,M
J = 0
L = 0
READ 1,K
READ 2,M
READ 3,N
READ 4,O
READ 5,P
INTCON = %10001000 ; Set/re-set interrupt enable bit - clear flags
ON INTERRUPT GOTO MYINT
IF Q = 1 THEN
GOTO DSLEEP
LOOP:
SLEEP 3088
GOTO REFRESH
GOTO LOOP
DSLEEP:
IOCB = %00001010
SLEEP N
IOCB = %00001011
Q = 0
GOTO LOOP
