Buttons are driving me nuts
Don't you hate when you got the complicated thing to work, but the simple things just seem beyond you?
I'm building a IR Camera trigger using a PIC 16F648A, and I spent all last night getting the 38.5Khz modulated carrier to work perfectly. I was testing it on a timer, so that every 5 seconds, it would send the pulse out. I now want to try triggering it from a button press, but I don't seem to be having ANY luck getting the PIC to see the press.
Code is as follows:
@ device pic16F648A, wdt_off, intrc_osc_noclkout, mclr_off, protect_off
CMCON = 7 ' Turn all comparators to fully digital (needed??)
TRISB.3 = 0 ' IR Output Pin
TRISB.4 = 1 ' Shutter Input Pin
HPWM 1,127,38500 ' Configure HPWM for 50% duty cycle PWM signal at 38.5kHz
CCP1CON = 0 'PWM OFF
start:
while TRISB.4 = 1 : WEND
gosub shutter
pause 250
goto start
I've tried using "While TRISB.4 = 0 : WEND", and that (if memory serves) just fires the subroutine constantly (which makes sense).
I've attached the "schematic" for how the button is attached, just in case I've mangled that somehow. The button is a normally open momentary contact. I've checked with a logic probe that B4 on the PIC sits low normally, and goes high with the button press.
Sadly enough, I'm pretty sure this is going to be one of those simple "you missed..." answers.
Thanks in advance!
