What I'm trying to do is use Hyperterminal to send keys pressed from the computer keyboard to the Lab x-1 LCD but only on the first line of the LCD and to hyperterminal, also send the keys from the Lab x-1 keyboard to Hyperterminal and also to line 2 of the LCD. The code I have below does that but I want to be able to see all the keys I've been pressing and not have them be cleared each time I press a key on either keyboard so in other words have them saved on their corresponding lines. Any help or pointing in the right direction would be helpful.
Code:Define LOADER_USED 1
Define LCD_DREG PORTD
Define LCD_DBIT 4
Define LCD_RSREG PORTE
Define LCD_RSBIT 0
Define LCD_EREG PORTE
Define LCD_EBIT 1
char var byte ' Storage for serial character
col var byte ' Keypad column
row var byte ' Keypad row
key var byte ' Key value
lastkey var byte ' Last key storage
ADCON1 = 7 ' Set PORTA and PORTE to digital
Low PORTE.2 ' LCD R/W line low (W)
Pause 500 ' Wait for LCD to startup
OPTION_REG.7 = 0 ' Enable PORTB pullups
key = 0 ' Initialize vars
lastkey = 0
Lcdout $fe, 1 ' Initialize and clear display
loop: Hserin 1, tlabel, [char] ' Get a char from serial port
LCDOUT $fe, $80, char ' Send char to display
HSEROUT [char] ' Send char to Hyperterminal
tlabel: Gosub getkey ' Get a keypress if any
If (key != 0) and (key != lastkey) Then
LCDOUT $fe, $C0, key ' Send key out serial port
HSEROUT [key] 'Send key to hyperterminal
Endif
lastkey = key ' Save last key value
Goto loop ' Do it all over again
' Subroutine to get a key from keypad
getkey:
key = 0 ' Preset to no key
For col = 0 to 3 ' 4 columns in keypad
PORTB = 0 ' All output pins low
TRISB = (dcd col) ^ $ff ' Set one column pin to output
row = PORTB >> 4 ' Read row
If row != $f Then gotkey ' If any keydown, exit
Next col
Return ' No key pressed
gotkey: ' Change row and column to ASCII key number
key = (col * 4) + (ncd (row ^ $f)) + "0"
Return ' Subroutine over
