KeithH
I have placed LEDs on the Shift register's Parallel out pins along with a current limiting 680R resistor on each pin. I am intending to create a chain of 30 or more shift registers so don't want to loose too much power over the whole chain. I am not too hot on the electical side of this so for me this will be trial and error. I can't really say exactly what I am trying to make except to say it will have a lot of LEDs on a chain of shift registers, all spaced about an inch apart and wired together, i.e. not on the same PCB. So there is a lot of room for leakage and noise etc. Is it a good idea to use the Resistors or should I look for a register/LED combination that draws the least power per LED? Also it would make it easier to build if I didn't need the 210+ resistors. Any suggestions would be appreciated.
Thanks.
