Bootloader Hardware Modification
Many of you are using a BootLoader with a standard BootLoader Hardware (Loader Cable with MAX232)
You may have realised that this cable can't be used for serial communication with other devices.
(i.e. PIC to PC Communication using HyperTerm)
The Reason is: MCLR on the PIC is pulled permanently LOW by the external device. (DTR on the DB9)
A small modification on the BootLoader Hardware makes Life a lot easier.
The attached schematic shows the standard BootLoader Hardware and the required modification.
(Replace the 100 Ohms Resistor with a 10uF Tantalum Capacitor)
see schematic:
