1/ 100th second Slot car Timer
I am trying to build a timer for my slot car track with VB and a pic. I am using a pic 16f84a but can also use the 877 for more I/O ports. My question is this ..
Can the 9800 baud (whatever) serial com port handle a 1000th of a SECOND input or will it crap out under the speed it takes to get the signal and process it into the monitor. I could just trigger the built in timer for VB but as we all know it is not the most accurate of controlls. I want the Pic to tell the PC the elasped time in real time. I might be able to use get time option in VB but I want to use the PIC. Once I get the signal into VB I can generate charts., graphs whatever I just need to know should I be trying to solve this in pic basic and send the info to VB or vice versa....
Any suggestions (There are no wrong answers)
Sorry, I was misled by the positive results
I have finally finished my slot car timer, I had to totally scrap my pot the cad pin programming because it took to darm long. the better way was to use the IR beam break tecnology and use that for my signals. The biggest problem turnrd out to be DC EMI of spikes caused by the car motors. I fixed that in the programming E-mail me if you are designing a simular project and I will help as best I can. Thanks to the forum for all the help.
Snap
