Hello guys.
Just a question.
I built a tool machine that move by DC motor.
I'm powering a 24VDC motor by a PIC 16F877 with LM629 Precision Motor Driver Controller and the power stage is built with LMD18201T.
The motor is far away from the controller board.
Anything seems to work fine BUT SOMETIMES I see that OTHER boards that come closer to this motor when the tool machine is moving pick some disturbance coming sure from the motor (like a coupled magnetic field). Actually the hall effect sensors used as encoder and that are on a tiny motor inside the board that get noise are no switching at all when the structure is close to the big motor. If I move the board (and the tiny motor) that get noise, away from the motor while he is running, the board with the tiny motor start working properly.
The big motor seems to have filter capacitors.
I want to try something different.
What you thing about SNUBBER solution?
I'm asking because in this case, the inductive load (the big motor) is powered by a PWM signal coming from the LM629/LMD18201T also when the motor shaft is not turning. Actually the system hold the motor rock steady until the control board command some coordinates to move to.
I've experienced that I get noise (of course) also when the shaft is steady, because there is continuously a PWM signal about 50% duty cycle.
I saw, also, that modifing the path of big motor leads the problem LOOKS LIKE disappeared... but I want to be sure about this...
Shortly:
I have two boards. One is steady and have big motor controllers on it. Big motor is far away from this board (around 21 inchs). It work fine.
I have another board that is moving by the big motor above. This board have on top a tiny 24VDC motor with a 2 channel encoder built with 2 Allegro hall-effect chips (90° phase)
Looks that the 2 Allegro are like saturated when they are close to the big motor.
The big motor specs are:
V = 24VDC
Imax = 5A at startup only
I don't know the inductance...
Power for both big and tiny motor is coming from a 24VDC industrial power supply (very well done)
Power for the logic of the main controller board AND for the board that get noise is coming from ANOTHER 9VDC industrial power supply (also this very well done).
Grounds from the 24VDC and from 9VDC are completely separated.
Both boards have 0.1uF decoupling capacitors everywhere.
Actually I DON'T get microprocessor strange behaviour. Simply I do not see incoming pulses into RA.4 (setup as timer0) when the "moving" board get close to the big motor. In that condition microprocessor still work as expected, also still able to send back the error condition by the serial port and also still able to get other commands from his serial port.
Seems that I have to screen the big motor in some way.
Do you thing that a snubber (if applicable) could be the final solution?
Or, if the snubber is not applicable, do you could suggest a solution?
Thank you a lot.
