pk7639
My circuit uses GP3 as an input (I modified 12F508.inc) and INTRC_OSC
The second block of this code (starting with the lable ccw:) loops at about 1/6th of the speed of the bit below the if statement???
Anyone seen anything like this?
Many thanks in advance
PK
OPTION_REG.5=0 'need to set this to use pin2 as an output
OPTION_REG.6=0 'this turns on the internal pull up resistors
stepDelay con 20 'delay in mS for each step
TRISIO=%01000 'set GPIO.3 as an input, all othe pins as outputs
loop: if GPIO.3=1 then ccw
GPIO=%00110
pause stepDelay
GPIO=%00101
pause stepDelay
GPIO=%10001
pause stepDelay
GPIO=%10010
pause stepDelay
goto loop
ccw: GPIO=%10010
pause stepDelay
GPIO=%10001
pause stepDelay
GPIO=%00101
pause stepDelay
GPIO=%00110
pause stepDelay
goto loop
