skimask
Whoa...ease up there Sparky...
Ya gotta figure...somebody comes on-line, asking questions which should be obvious 'cause they're in the manul, says there is no manual, is doing some sort of senior project at a University... Again, it all sounds fishy to me...but that's not the point...
The posts I've given here are MINE...nobody's else, just mine and only mine. Don't take my 'opinions' as the rules around here. There may be people around here that are a lot more giving than I am, good for them. I look for a bit of 'one hand washes the other' type thing. You ask a question, I give you the answer, hopefully that answer can lead you to other answers, so you don't have to ask as many questions.
As a 'for instance'...you stated in post #4 that the 16F88 doesn't have an internal oscillating crystal. Well, you would've known that the 16F88 had it's own internal oscillator block that can run at a number of speeds if you'd have read the datasheet, and not even read it, but at least skimmed over it fairly well.
That's the kind of thing I'm talking about...the blatently obvious question that could've been avoided by the least bit of 'research'. And there ya go...
So...after you have taken my advice written in post #3 into account and have made some changes to your code. Recompile the code, work the hardware, try it out, and let us know what's up...
