Hi all,
i've got a question for you,
I've a Geiger-Muller Tube, an instrument for measuring radiations, which gives me an output in the form of a pulse of minimum 90uS,
i need to measure the number of pulses per second with the minimal possible error,
cause the pulse is minimum 90uS every second i can have at max
1.000.000uS / 90uS = 11.111 CPS (Counts Per Second)
this means that every 5 seconds i have to store the variable in an I2C memory (To be downloaded in a PC)
i was thinking to something like a loop to check for the pulses and store them in a RAM word-sized variable and use an interrupt that every 5 seconds store the variable into the I2C mem,
like this:
GEIGER VAR PORTD.0
CNT VAR WORD
ADD VAR WORD
CONTROL VAR BYTE
CONTROL = $A0
ADD = 0
CheckLoop:
IF GEIGEG THEN
CNT = CNT + 1
GOTO CheckLoop
IntHand:
I2CWRITE SDA,SCL,CONTROL,ADD,[CNT]
ADD = ADD + 1
CNT = 0
RESUME
Do you think it would suit me? (I don't know a lot about pic timing...)
there would be a better way to count or to check for the pulse? (i'm not interested in the pulse lenght)
(Please ignore the missing TMR or INTCONT)
Thank you,
Luca
