hi friends i search in the forum and found many examples thanks. i have pic 16f876 , 20 mhz osc and 1 led ,i have dmx512 lighting desk too and i want to dimm a led on dmxadres 1 (0-255 to led intensty) but there is some problem on this code it is not working. i found this code in the forum and made it again for my pic but couldnt find the problem.can you look to my code and say what is my problem here?or you can send other example code to receive dmx ..
' PIC 16F876 - 20MHZ OSC
DEFINE OSC 20 ' 20 MHZ OSC
DEFINE HSER_TXSTA 24h ' Enable transmit
DEFINE HSER_SPBRG 4 ' 250 000 Baud @ 20MHz, 0.0%
ERRORLEVEL -306, -302
ADCON0 = 0
ADCON1 = 7
counter var word
idleflag var word
dummy var word
RCIF VAR BYTE
startcode var word
aminus var word
adress var word
x var word
level1 var word
adress = 1 ' My Start Adress
checkdmx:
counter = 1 ' Dummy variable
pulsin portC.7,0,counter 'Here looking for the break signal
if counter = 0 then
idleflag = 1 'either no dmx , or break was too long to count
'return
if counter < 40 then checkdmx ' watching for "break"
dummy = RCREG
dummy = RCREG
SPBRG = 0
TXSTA.2 = 0
TXSTA.4 = 0
RCSTA.7 = 1
RCSTA.6 = 0
RCSTA.4 = 0
RCSTA.4 = 1
while RCIF = 0: wend
startcode = RCREG 'firs byte after break
if startcode <> 0 then checkdmx
aminus = adress -1
for x = 1 to aminus
dummy = RCREG
next x
level1 = RCREG
portC.1 = level1 'i want to dimm led on port c.1
RCSTA.7 = 0
goto checkdmx
