I2C configuration
since i got the PicBasicPro i have a hard time leaving it. Wanting to learn all i can. I have note left and right since i started.I appreciate the help from everyone but i have another question.
I have searched for I2C config with no results that reallt explains what i want to know.
I am working with the TC74a05 address 1001 101
control = %1001101 <--------Is this declared by PicBasic Pro that i don't have too.
addr = $00 <--------Is this declared by PicBasic Pro that i don't have too.
i2cwrite sda,scl,control,addr,[$00]
I have this device reading the temp. What i want learn is to write to the config area and put it in standby.
The 7 bits of control are really the address of the chip with a r/w bit as the 8 bit but actuall bit0, correct? The addr is what? and the [$00] is the data to write? Do i have to do 2 write commands to do a configure?
The documentation says.
Is this the [$00]?
Command Code Function
RTR 00h Read Temperature (TEMP)
RWCR 01h Read/Write Configuration
Where does this go? In the Addr area?
CONFIGURATION REGISTER
(CONFIG); 8 BITS, READ/
WRITE)
D[7] 0 STANDBY Switch Read/Write
1 = standby,
0 = normal
D[6] 0 Data Ready * Read Only
1 = ready
0 = not ready
D[5]-D[0]
Reserved -
Always
returns zero
when read
You have to shift the I2C-adress to the left by 1 bit.
So you get %10011010 as the adress.
I know, it is only very bad written in the manual, but ...
Sorry,
in your words, the I2C-adress is the control-word.
So you have to change the single line
to
control = %10011010 <--------Is this declared by PicBasic Pro that i don't have too.
Thank you Big Wumpus for the help and replys.
Merlin Knight
