DMX512 Problem ..Schema+Code
i want to make code for dmx512 protocol i have 9 dipsw on my project and 3 led i want to make 512 adres with the dips. and i will make pwm control for my 3 leds as a seperate it means dmx512 control with 3 chanel i have schema and code but not working can you help me please?
' 512 Kanal DMX SLAVE
'******************** INCLUDE FILES **********************
INCLUDE "modedefs.bas"
'******************** REGISTER **********************
DEFINE HSER_TXSTA 24h
DEFINE HSER_RCSTA 90h
'DEFINE HSER_SPBRG 129
DEFINE HSER_BAUD 9600
DEFINE HSER_CLROERR 1
CMCON = 7 ' Disable analog comparator
'******************** DEĞİŞKENLER **********************
DipAdrr VAR WORD ' 512 Veya 1024 Adresle İçin WORD
DipAdr_L VAR DipAdrr.Byte0 ' 512 Veya 1024 Adresle İçin
DipAdr_H VAR DipAdrr.byte1 ' 512 Veya 1024 Adresle İçin
DmxAdrr VAR WORD
DmxAdr_L VAR DmxAdrr.Byte0
DmxAdr_H VAR DmxAdrr.Byte1
IntData VAR BYTE[4] ' Kesme Data Dizisi
DmxData VAR BYTE ' Networkten Gelen Data
DmxChanel VAR BYTE ' DMX Kanal
DmxCom VAR BYTE ' Dmx Komut
Addr VAR BYTE ' Genel Sayac
KesmeSayac VAR BYTE ' Kesme Sayac
'******************** ATAMALAR **********************
Led_G VAR PORTB.0 ' Green Led
Led_R VAR PORTB.3 ' Red Led
Led_B VAR PORTB.7 ' Blue Led
DipAdr0 VAR PORTA.0 ' Dip Swicht 0
DipAdr1 VAR PORTA.1 ' Dip Swicht 1
DipAdr2 VAR PORTA.2 ' Dip Swicht 2
DipAdr3 VAR PORTA.3 ' Dip Swicht 3
DipAdr4 VAR PORTA.4 ' Dip Swicht 4
DipAdr5 VAR PORTB.4 ' Dip Swicht 5
DipAdr6 VAR PORTB.5 ' Dip Swicht 6
DipAdr7 VAR PORTB.6 ' Dip Swicht 7
DipAdr8 VAR PORTA.5 ' Dip Swicht 8
GIE VAR INTCON.7 ' Global İnterrupt Enable Bit
PEIE VAR INTCON.6 ' Çevresel İnterrupt Enable Bit
T0IE VAR INTCON.5 ' Timer0 İnterrupt Enable Bit
INTE VAR INTCON.4 ' PORTB İnterrupt Enable Bit
RBIE VAR INTCON.3 ' Up PORTB İnterrupt Enable Bit
T0IF VAR INTCON.2 ' Timer0 Flag Bit
INTF VAR INTCON.1 ' PORTB.0 Flag Bit
RBIF VAR INTCON.0 ' PORTB Flag Bit
RCIF VAR PIR1.5 ' Receiver Enable Bit
TXIF VAR PIR1.4 ' Transmit Enable Bit
SYNC VAR TXSTA.4 ' Usart Mode Select Bit 1=Senkron, 0= Asenkron
SPEN VAR RCSTA.7 ' Serial Port Enable Bit
RX9 VAR RCSTA.6 ' 9 Bit Receive Enable Bit
SREN VAR RCSTA.5 ' Single Receive Enable Bit
CREN VAR RCSTA.4 ' Continuous Receive Enable Bit
ADEN VAR RCSTA.3 ' Address Detect Enable Bit
FERR VAR RCSTA.2 ' Frame Error Bit
OERR VAR RCSTA.1 ' Overrun Error Bit
RX9D VAR RCSTA.0 ' 9 Bit Of Receive Bit
'******************** PORT YONLERI **********************
TRISA.0=1 ' IN
TRISA.1=1 ' IN
TRISA.2=1 ' IN
TRISA.3=1 ' IN
TRISA.4=1 ' IN
TRISA.5=1 ' IN
TRISB.0=0 ' OUT
TRISB.3=0 ' OUT
TRISB.4=1 ' IN
TRISB.5=1 ' IN
TRISB.6=1 ' IN
TRISB.7=0 ' OUT
Addr = 0
KesmeSayac = 0
PIE1.5 =1 ' Enable USART receive interrupt
INTCON.6 =1 ' Enable peripheral interrupt
ON INTERRUPT GoTo DmxKesme
Main : GoSub DipOku
DmxAdr_L = IntData[0]
DmxAdr_H = IntData[1]
DmxCom = IntData[2]
DmxChanel = IntData[3]
IF DmxAdrr = DipAdrr Then
IF DmxCom = "1" Then
IF DmxChanel = "1" Then
High Led_G
EndIF
IF DmxChanel = "2" Then
High Led_G
EndIF
IF DmxChanel = "3" Then
High Led_G
EndIF
EndIF
IF DmxCom = "0" Then
Low Led_G
EndIF
Low Led_G
EndIF
Low Led_G
EndIF
EndIF
EndIF
GoTo Main
'******************** ADRES OKU **********************
DipOku : DipAdrr.0 = DipAdr0
DipAdrr.1 = DipAdr1
DipAdrr.2 = DipAdr2
DipAdrr.3 = DipAdr3
DipAdrr.4 = DipAdr4
DipAdrr.5 = DipAdr5
DipAdrr.6 = DipAdr6
DipAdrr.7 = DipAdr7
DipAdrr.8 = DipAdr8
DipAdrr.9 = 0
DipAdrr.10 = 0
DipAdrr.11 = 0
DipAdrr.12 = 0
DipAdrr.13 = 0
DipAdrr.14 = 0
DipAdrr.15 = 0
'******************** KESME **********************
Disable INTERRUPT
DmxKesme : DmxData = RCREG
IntData[Addr] = DmxData
IF Addr = 4 Then
Addr = 0
Else
Addr = Addr + 1
EndIF
RCSTA=$90
Resume
Enable INTERRUPT
