Oscillation maximum
Hello,
I would like toknow if the follwoing is possible in picbasic .
I have a sensor that needs to be clocked at 2Mhz. I would like the Pic to read the amount of clockings, and sends out a pulse at the 129th clock. the pulse should have similar rise , hold and fall time as the clock.
I found this link:
http://www.fh-aalen.de/dti/o_mess/Pixcntr.txt
which the person seems to have programmed a chip to do so.
the picbasic manual basically tells me it is impossible beause it is too high speed.
Any suggestion,? even is it not pic based
thank you
ken
Ideally I would like to have the following output
a 25khz frequency, with 1.2% duty cycle
I am clocking a sensor chip at 2Mhz, I want to send a high on every 130th cycle wich will not be longer then a cycle of the 2Mhz.
k
even more basically,
I want to send a 0.5us pulse every 40us.
I have this program below, nothing is coming out of it, althou if i remove the line :DEFINE OSC 20, it works. How do i set my 20mhz ?
Below without the define 20, it gves me an oscillation of 125Khz
@ DEVICE PIC16F88, MCLR_ON,HS_OSC, WDT_ON, LVP_OFF, BOD_OFF, PWRT_ON, PROTECT_OFF, CCPMX_ON
INCLUDE "modedefs.bas"
DEFINE OSC 20 'use external 20mhz crystal
CMCON = 7 : ANSEL = 0 : ADCON1 = 7
DEFINE CCP1_REG PORTB 'Hpwm 1 pin port, RIGHT
DEFINE CCP1_BIT 3 'Hpwm 1 pin bit
TRISB = %00000000
PAUSE 1000 ' start-up delay
HPWM 1,3,25000
loop:
goto loop
oddly enough even if I change to lower values like:
HPWM 1,3,15000
it do not work
