problem with 16f877 and display
I'm getting trouble with a HD44780 compatible lcd display
and a pic16f877a that doesn't work togheter!
Display it's ok when connected to another circuit made around a PIC16f628
Data and control signals are on port "A"
data are from A0 to A3
RS is on A5
E is on A4
at the top of the program i put the following defines
(In the program there aren't other assignment for PORT A)
DEFINE LCD_DREG PORTA 'LCD data port
DEFINE LCD_DBIT 4 'LCD data starting bit 0 or 4
DEFINE LCD_RSREG PORTA 'LCD register select port
DEFINE LCD_RSBIT 5 'LCD register select bit
DEFINE LCD_EREG PORTA 'LCD enable port
DEFINE LCD_EBIT 4 'LCD enable bit
DEFINE LCD_BITS 4 'LCD bus size 4 or 8
DEFINE LCD_LINES 2 'Number lines on LCD
DEFINE LCD_COMMANDUS 2000 'Command delay time in us
DEFINE LCD_DATAUS 50 'Data delay time in us
then the first output on LCD is simply made using:
PAUSE 1000
LCDOUT $FE,1, "TEST LCD"
result: no output on LCD
what's wrong !?!?!?!?
