Hi all,
I guess this is a question more about the MSCOMM object within VB6 than PICs however, it may turn out the other way.
I'm sending serial data to the PC and displaying the data in several text boxes. The connection between the PC and PICF628 begins when the VB6 form opens and the user initiates a request from the PIC. The PIC then sends 5 differnent variables plus a couple of characters at the front so that I could rip out the two command char which indicate which text box to display the data. I'm using the DEBUG @ 300 BPS for communication.
The funny thing is that when any other data is sent after the initialization the PC comm port seems to have shifted (right) to places. I've attached both the PC code and a snippet from a large PIC file.
I must mention that some of the VB code I obtained was off Rentron.com, I just added a few things.
Oh, and one more thing, the days of frustration over the PICF88, was due to a decoupling cap, thanks for everyones advice especially Steve.
I'm thinking that maybe I need to encapsulate the data in control characters then strip them out at the other end. But after looking at the output of the pic using (MCS Communicator) when the initialistion command is given, I can't see any errors. ?????Code:
Private Sub cmdinit_Click()
Dim out As String
out = "k"
MSComm1.Output = out 'command to PIC to begin sending data.
End Sub
Private Sub Form_Load()
Dim i As Integer
Dim send_data As String
Dim InStr As String
MSComm1.CommPort = 2
' Fire Rx Event Every Two Bytes
MSComm1.RThreshold = 6
'If MSComm1.InBufferCount = 6 Then
' When Inputting Data, Input 6 Bytes at a time
MSComm1.InputLen = 6
'End If
' 300 Baud, No Parity, 8 Data Bits, 1 Stop Bit
MSComm1.Settings = "300,N,8,1"
' Disable DTR
MSComm1.DTREnable = False
' Open the port
MSComm1.PortOpen = True
End Sub
Public Sub MSComm1_OnComm()
Dim sData As String
If MSComm1.CommEvent = comEvReceive Then
sData = sData & MSComm1.Input
sData = MSComm1.Input ' Get data (2 bytes)
End If
Call display(sData)
End Sub
Public Sub display(instring As String)
Dim cmdword As String 'hold the command word
Dim word As String 'holds the data
Dim outstring As String
If Len(instring >= Limit) Then
outstring = instring
instring = Right$(instring, Len(instring) - Limit) 'clears the buf
Call handleinput(outstring)
End If
End Sub
Sub handleinput(displaystr As String)
Dim newstring As String
cmdword = Left(displaystr, 2) ' rip out the command
word = Mid$(displaystr, 3, 4) 'rip out the data to be displayed
Select Case cmdword
Case "OK"
Case "aa" 'lower bound
lower.Text = word
Case "bb" 'upper bound
upper.Text = word
Case "cn" 'step count
stepcnt.Text = word
Case "ab"
focus1.Text = word
End Select
End Sub
PIC code
init: '
sendlower:
debug "aa", #lower
PAUSE 100
debug "bb", #upper
PAUSE 100
sendstepcnt:
debug "cn", #stepcnt
PAUSE 100
sendf1:
ADDR_L=1
ADDR_H=2
GOSUB readset
DataA.byte0 = RDDATA_L
DataA.byte1 = RDDATA_H
debug "ab", #DataA
