usb - device not recognised
my code, create by easyhid
DEFINE OSC 48
DEFINE LOADER_USED 1
USBBufferSizeMax con 8 ' maximum buffer size
USBBufferSizeTX con 8 ' input
USBBufferSizeRX con 8 ' output
' the USB buffer...
USBBuffer Var Byte[USBBufferSizeMax]
USBBufferCount Var Byte
' * main program loop - remember, you must keep the USB *
' * connection alive with a call to USBService every couple *
' * of milliseconds or so... *
usbinit ' initialise USB...
ProgramStart:
gosub DoUSBIn
gosub DoUSBOut
goto ProgramStart
' * receive data from the USB bus *
DoUSBIn:
USBBufferCount = USBBufferSizeRX ' RX buffer size
USBService ' keep connection alive
USBIn 1, USBBuffer, USBBufferCount, DoUSBIn ' read data, if available
' * wait for USB interface to attach *
DoUSBOut:
USBBufferCount = USBBufferSizeTX ' TX buffer size
USBOut 1, USBBuffer, USBBufferCount, DoUSBOut ' if bus available, transmit data
i tryied cristal 20mhz or 8mhz and "device not recognised",
with 48 not detect
i tested demo program usbcdc and too "device not recognised".
