Speed of USB EasyHID and Time problem
I'm working on a project measuring high pulse and then during the low pulse, send the value by USB to a VB app.
The problem is that when the period (High and Low pulse) is shorter than aprox 7ms I get strange data from the pic.
I decided to measure how long time a USBOut and USBSERVICE takes and here is what I got:
USBSERVICE = 4.08us
USBOut 8 Byte = 12.4us
USBOut 16 Byte = 15.7us
USBOut 32 Byte = 22.4us
USBOut 64 Byte = 35.7us
So the USB transfer should not affect my measurements of the pulse width.
I use Timer3 to measure parts of my program.
The part of code I measure in the pic code below takes 15.5us.
I use a Basic Stamp to create a squarewave to my pic CCP1 input.
The program looks like this:
IF IN15 THEN
HIGH 6
PAUSE 3
LOW 6
PAUSE 4
GOTO Main
In this case I get correct readings sent to the pc.
But if I change Pause 4 to Pause 3 the data variates a lot.
Also the Timer3 values in the pic code below variates a lot.
Wich means that that part of code takes different times to execute from time to time.
If I change the Basic Stamp program to this; the data is correct:
IF IN15 THEN
HIGH 6
PAUSE 0
LOW 6
PAUSE 7
GOTO Main
And also this works:
IF IN15 THEN
HIGH 6
PAUSE 7
LOW 6
PAUSE 0
GOTO Main
But as soon the period is under 7ms I get strange values to my vb app.
Please help me find what is wrong with my code.
I use a Pic18F4550 20Mhz, MicroCode Studio Plus and Pbp 2.46.
Thanks in advance,
Stefan
'Pulse width measuring
DEFINE OSC 48
DEFINE LOADER_USED 1
DEFINE RESET_ORG 800h ' For Microchip USB Bootloader
DEFINE INTERRUPT_ORG 808h ' For Microchip USB Bootloader
USBBufferSizeMax con 8 ' maximum buffer size
USBBufferSizeTX con 8 ' input
USBBufferSizeRX con 8 ' output
USBBuffer Var Byte[USBBufferSizeMax]
USBBufferCount Var Byte
Counts1 Var Word ' Holds Timer1 counts
Counts1Of Var Byte ' Holds the Overflow counts
Overflow var byte
RisingEdge Var Bit
Preset Var Bit
SendBytes Var Bit
SampleNo var byte
NewSample var byte
CCP1IE var PIE1.2
CCP1IF VAR PIR1.2
TMR1ON VAR T1CON.0
TRM1IF var PIR1.0
TMR1IE VAR PIE1.0
IrOnRising var BYTE
IrOnFalling var BYTE
x var byte
y var byte
Led VAR PortB.5
'Timer3 declarations
TMR3ON var T3CON.0
TMR3IF var PIR2.1
TMR3IE var PIE2.1
TMR3VALUE var WORD
TMR3OverF var byte
USBINIT
ADCON1 = 15 ' Set PORTA, PORTE and PORTB to digital.
TRISD.1 = 0 'Port D Bit 1 as Output
TRISB.5 = 0 'Port B Bit6 as Output for LED
TRISC.2 = 1 'Port C Bit2 CCP1 as Input
IrOnFalling = 4 '0100 = Capture mode: every falling edge
IrOnRising = 5 '0101 = Capture mode: every rising edge
T1CON.4 = 1 'Timer1 Prescaler Bit4
T1CON.5 = 1 'Timer1 Prescaler Bit5
Counts1 = 0
TMR1H = 0
TMR1L = 0
CCP1CON = IrOnRising '0101 = Capture mode: every rising edge
CCP1IE = 1 'CCP1IE Interrupt Disabled
SampleNo = 1
Counts1Of = 0
Overflow = 0
Low Led
'Timer3 inits
TMR3OverF = 0
TMR3IE = 1
TMR3IF = 0
T3CON.4 = 0
T3CON.5 = 0
ProgramStart:
USBSERVICE ' keep connection alive
if TRM1IF THEN 'If Timer1 Overflows
Overflow = Overflow + 1 'Incr Overflow counter
TRM1IF = 0 'Reset Flag
IF CCP1IF = 0 THEN ProgramStart 'Return if no Interrupt
IF CCP1CON = IrOnRising THEN
CCP1IF = 0 'Reset Flag
CCP1IE = 0 'CCP1IE Interrupt Disabled
CCP1CON = IrOnFalling 'Capture mode: every falling edge
CCP1IE = 1 'CCP1IE Interrupt Enabled
TMR1H = 0
TMR1L = 0
TMR1IE = 1 'Enable overflow flag
TMR1ON = 1 'Start Timer 1
' high Led
goto ProgramStart
IF CCP1CON = IrOnFalling THEN
TMR3ON = 1 'Using Timer3 for measuring
Counts1.HighByte = CCPR1H 'Save Values
Counts1.LowByte = CCPR1L
Counts1Of = Overflow
Overflow = 0 'Reset Overflow counter
CCP1CON = IrOnRising 'Capture mode: every rising edge
'TMR1ON = 0 'Stop Timer 1
TMR1H = 0
TMR1L = 0
if SampleNo = 1 then 'SampleNo used by VB app.
SampleNo = 2
SampleNo = 1
USBBuffer(0) = Counts1.LowByte
Counts1.LowByte = 0
USBBuffer(1) = Counts1.HighByte
Counts1.HighByte = 0
USBBuffer(2) = Counts1Of
USBBuffer(3) = SampleNo
USBBuffer(4) = TMR3VALUE.highbyte
USBBuffer(5) = TMR3VALUE.lowbyte
'low Led
Gosub DoUSBOut
TMR3ON = 0 'Using Timer3 for measuring
TMR3VALUE.highbyte = TMR3H
TMR3VALUE.lowbyte = TMR3L
TMR3H = 0
TMR3L = 0
goto ProgramStart
GOTO ProgramStart
' * receive data from the USB bus *
DoUSBIn:
USBBufferCount = USBBufferSizeRX ' RX buffer size
x=x+1
if x > y THEN Skipping
USBService ' keep connection alive
USBIn 1, USBBuffer, USBBufferCount, DoUSBIn ' read data, if available
Skipping:
x=0
' * wait for USB interface to attach *
DoUSBOut:
USBBufferCount = USBBufferSizeTX ' TX buffer size
USBOut 1, USBBuffer, USBBufferCount, DoUSBOut ' if bus available, transmit data
Can someone please help me to find out why I'm not able to measure higher freq than 67Hz. Is it the speed of the USB transfer that takes too long time?
I would really apreciate if you can help me.
Stefan.
