Can't remove code protection of 16F88!!!
Hello,
I just can't remove the code protection of my 16F88. Something must have gone wrong during a programming process since I never use this protection mode.
I'm using two different programmers: the AN589 (parallel) & and the VELLEMAN "8076'1" (serial). Both work usually fine.
I'm programming the chips using the ICSP method.
I have found some older threads about this type of issue and tried almost anything possible.
Is there any "master" reset possible for this chip?
Which Programming Software are you using ?
Have you tried erasing the MCU ? A bulk erase should remove the code protection bits as well.
Low Voltage Programming - possible solution?
Just an idea: would it be possible to overcome the code protection issue by programming the PIC with a Low Voltage method?
Actually, I've never done this so I don't know how to do and and if it would work.
BTW: I put the µC on my breadboard with "nothing" connected to it appart from a 0,1µF cap between Vdd and Vss.
