Pic16f84 ---> Pic16f628
Hi to all
Preciso aid of alguem experienced, my knowledge in this subject still is in the start, in my Brazil country pic16f84 is more expensive here (around $10,00) and pic 16f628 is cheaper (around $3,00) therefore would like to modify the code below that it was written for pic16f84 to be used in the 628, as I said before still I do not have experience for this, use soft IC-prog I eat interface AN589, I alguem I can help me?
I am thankful anticipatedly.
; message.asm
; This code makes a message appear in mid air.The 5 leds are connected to portb. RB0 - RB4
; put new message in below. NOTE: messages too long are a problem, as the
; 'persistence of vision' doesn't work.
; LEDS connected to port RB0 - 4 tilt/accelerometer to RA0 to start text
; letters are in columns. i.e letter A
; 0110
; 1001
; 1001 the 1's make up the A. 1 = LED on. 0 = off
; 1111
; 1001
; By Barry Carter
LIST P=16C84;f=inhx8m
w equ 0 ; register destination addresses.
f equ 1
same equ 1
z equ 2 ; status flags
zero equ 2
c equ 0
carry equ 0
count1 equ 0C ; wait counter ls digit file register C
count2 equ 0D ; wait counter ms digit file register D
portb equ 06 ; port b I/O register f6
porta equ 05 ; port a I/O register f5
status equ 03 ; status register f3
time equ .15
org 0 ; origin
init
movlw 0 ;initialise port settings
tris portb
movwf portb
movlw 1
tris porta
bcf porta,0
start
goto getbut
;* TYPE YOUR MESSAGE IN HERE *
letters call lh ;type in letters here.
call le
call ll
call ll
call lo
goto getbut ;goto get button input
;* FINISH MESSAGE SECTION *
getbut bcf status,1
movf porta,w ;gets input from start button on porta.0
movwf status ;read status register, to see value of porta
btfsc status,0
goto getbut ;if status = 1 then goto letter else goto getbut
goto letters
;*ROUTINES FOR OUTPUTING CHARACTERS TO LED'S ON PORTB*
;each letter is prefixed with l e.g la is a
la call wait ; wait for a bit
movlw B'00001111' ;output corresponding values out of portb
movwf portb
call wait
movlw B'00010010'
movwf portb
call wait
movlw B'00010010'
movwf portb
call wait
movlw B'00001111'
movwf portb
call space1
lb lz call wait ; wait for a bit
movlw B'00010001'
movwf portb
call wait ;
movlw B'00010011'
movwf portb
call wait
movlw B'00010101'
movwf portb
call wait
movlw B'00011001'
movwf portb
call space1
space1 movlw B'00000000' ;routine to put spaces between the letters
call wait
movlw B'00000000'
movwf portb
movlw B'00000000'
space2 nop ;loop forever
goto space2
;* wait subroutine *
wait
movlw time ; load count1 with decimal time
movwf count1
d1 movlw time ; load count2 with decimal time
movwf count2
d2 decfsz count2,same ; decrement F,skip if zero
goto d2 ; if not zero
decfsz count1 ; decrement count1 if count2 is zero
goto d1 ; do inside loop again if count2 nz
retlw 00
There are very few differences between a 16F88 and 16F628...
Firstly addd this to the defines at the start of your program...
cmcon equ 0x1F
Then also at the start of your program where the port tris registers are being defined add...
movlw 0x07
movwf cmcon
Look in the Datasheet (Section 9.0 & 9.1) to see what I have done.
