problem with output RA2 and RA3
I have the below code.
My problem is that the output RA2 and RA3 not change if (value - P2) >= 1 and (value1 - P3) >= 1.
What wrong i have made;
@ DEVICE PIC16F88, MCLR_OFF ' Master Clear Options (Internal)
'******************************** LCD ***********************************
DEFINE LCD_DREG PORTB ' Selection of the port B
DEFINE LCD_DBIT 4
DEFINE LCD_RSREG PORTB ' RS on port RB2
DEFINE LCD_RSBIT 2
DEFINE LCD_EREG PORTB ' E on port RB3
DEFINE LCD_EBIT 3
DEFINE LCD_BITS 4 ' Mode 4 bits
DEFINE LCD_LINES 2 ' LCD 2 lines of 16 caracter
'****************************Define ADCIN parameters **********************
DEFINE ADC_BITS 8 ' Set number of bits in result
DEFINE ADC_CLOCK 3 ' Set clock source (3=rc)
DEFINE ADC_SAMPLEUS 50 ' Set sampling time in uS
'*********************************** VARIABLES *********************
TRISA = %00000011
CMCON = 7 ' PortA = digital I/O
ANSEL = %00000011 ' Will set RA0-RA1 as analog and all others as digital
ADCON0 = %11100001 ' Configure and turn on A/D Module
ADCON1 = %00000010 ' Set PORTA analog and RIGHT justify result
adval var Byte ' Create adval to store result
value var Word
adval1 var Byte ' Create adval1 to store result
value1 var Word
P VAR Byte
P1 VAR Byte
P2 var Word
P3 var Word
PAUSE 500
LCDOUT $FE,1," VOLTMETER "
PAUSE 1000
P2 = P*50/255
P3 = P1*50/255
P2=28
P3=10
NORMAL:
ADCIN 0, adval ' Read channel 0 to adval
value = adval*50/255
ADCIN 1, adval1 ' Read channel 1 to adval1
value1 = adval1*50/255
LCDOUT $FE,1,"VOLT : ",DEC2 value
LCDOUT $FE,$C0,"AMPER: ",DEC2 value1
if (value - P2) >= 1 then
PORTA.2=1
PORTA.2=0
if (value1 - P3) >= 1 then
PORTA.3=1
PORTA.3=0
PAUSE 500
GOTO NORMAL
