18F4620 refuses to be re-programmed
hi,
I can only program one time (from empty) any 18F4620 part. Next times it gives lots of fails in verification (the piece remains with the first code programmed unchanged). My warp13 can program with no problem 18F2620. Is there any undocumented knowing or trick for programming the 18F4620?
Thanks.
Look at this thread for ideas
Hi Max,
A while back several of us were having problems programming PICs with PicStartPlus and it turns out there are known issues with some devices.
Check out this thread for possible ideas including the tip from Microchip to erase the device first and then reprogram.
http://www.picbasic.co.uk/forum/showthread.php?t=4710
HTH
Suggestions tested. Problem still on.
Thanks Skimask,
I have re-checked the setup of LVP both in the software line #pragma config ... and in the config bit table of the WARP13a application window for it to be unchecked/not selected. I have also tested the Vpp while programming and is 12.75 volts, clear and stable. The line RB5 is floating, must I pull it down even if I do not use LVP?
Any idea about why the pic let me to program one time and no more?
I read that some other pics showed this problem with MPLAB compatible programmers, but I have tried all the receipes (1-10K loading MCLR to GND, C 0.1µF from Vdd to Vss, ALL Vdd pins joined, ... ) and nothing seems to cure the problem.
It can not also be programmed neither the config bits nor the ID word of the PIC. Curiously, the first time (right after solder the part to the board) the programming was perfect.
Maxi.
