writting code for a 16 X 16 Table
This is my 1st post so i hope i got the right spot
i have PBP2.46
working with a PIC16f877a
having dificulties understanding the book on writting a table that is 16X16 see below
0123456789012345
1.......................
2.......................
3.......................
4.......................
5.......................
6.......................
7.......................
8.......................
9.......................
0.......................
all the spots will be placed with a linnear line of numbers ie 14.7,11.2,15.8 etc
this project is for measuring the air/fuel ratio on a car and displaying on a lcd.
any help would be great.
Crazy Cooter
No use to "bomb" the forum
FIRST ...
PbP only works with INTEGERS !!!
SECOND ...
PbP Works with Words ... where's your problem, then ???
THIRD ...
A look to JAYCAR ( Australia ) products could show you THE gadget you look for ... already cooked ... and working ( ! )
Custom Fuel injected Rideon
Thanks to everyone that responded. Its been great.
This project is for a fuel injected rideon. i have compleded an analogue circuit and it works ok. but i am not 100% happy with it. the o2 sensor is sensing if the engine is rich or lean. the pic's (16f877a @ 20MhZ) job is to make sure it stays correct at 14.7 with injecting the correct amount of fuel at its given RPM / LOAD thats why i am needing a table.
The max rpm the engine will do is 3600
Is there any way to make the table bigger than 16 X 16
ie 64 X 64?
thanking all in advance
