Was wondering if there was a template of sorts available.
Have .asm code & HEX, but will not work on PIC.(for some reason, yet it was designed for PIC apparently). The code it seems is a bit on the messy side, And thus far I have not found any tools that will convert assembler (.asm, mpasm,tasm, or any other) in Basic, Pascal, C etc. into something that will work. So it looks as if I must rewrite the code for PIC 16f877, in some form that ICprog & JDM programmer for instance, would accept and write to PIC & work...(as it is, the HEX & .asm codes will write to the CHIP but when installed in hardware...no go).
Thus, the question being is there template that is set out in ordered sections, whereby I can just change the variables?
Eg: LCD,GPS,etc...
Any input would be appreciated.
Thank you
All the best
