I've played about with "disco light controllers" based around PICs around this time last year. Rather than use triacs or thyristors to drive the mains lamps I used solid state relays. These work in exactly the same way as a normal relay, but have no mechanical parts, all the switching is done optically. This has the advantage of keeping the 240v mains AC isolated from the 5v DC side of the board. The ones I used operated from 5v DC and has such a low draw current could be driven direct from the PIC without the need for a driver transistor. Do a search on e-bay or some of the surplus electronic sites, I picked up 8 for around £1 each.
Triacs are triggered by current rather than voltage, and as most PICs can sink / sorce 25mA you should be able to drive them direct from the PIC. However, have a look at
http://ww1.microchip.com/downloads/e...tes/00958A.pdf which shows a triac used in a thermostat based around a PIC - the driver circuit (transistor) may be adapted to suit your needs.
