I have this configuration in my program
and this asm: (is for frequency meter)Code:' ******************************** LCD **************************************
DEFINE LCD_DREG PORTB 'Selection of the port B
DEFINE LCD_DBIT 4
DEFINE LCD_RSREG PORTB 'RS on port RA1
DEFINE LCD_RSBIT 2
DEFINE LCD_EREG PORTB 'E on port RA0
DEFINE LCD_EBIT 3
DEFINE LCD_BITS 4 'Mode 4 bits
DEFINE LCD_LINES 4 'LCD 4 lines of 16 caracter
PAUSE 500
' Define ADCIN parameters
DEFINE ADC_BITS 8 'Set number of bits in result
DEFINE ADC_CLOCK 3 'Set clock source (3=rc)
DEFINE ADC_SAMPLEUS 50 'Set sampling time in uS
INCLUDE "LCDbar_INC.bas" 'Include the BARgraph routines
CMCON = 7 'PortA = digital I/O
ANSEL = %00000111 'Will set RA2 as analog and all others as digital
and this asm: (is for frequency meter)Code:Asm
movlw 0x10 ;PORTA 4 in entry
movwf 0x5
MOVLW 0x37
option ;charge 00110111 in the register option
MOVLW 0x10 ;init freq with RA4 in entry
MOVWF _trisabuf
EndAsm
My problem is the pot not adjust the volt. Show on lcd only if it is full. If i turn litle the pot the volt go to 0volt on lcd.Code:;;;;;;;;;;;;;;;;;;;;;;;;;;;; AUTHORIZATION OF COUNTING
clrf TMR0 ; RAZ timer
bsf _trisabuf,3 ; RA4 in entry and RA3 in entry authorization counting
movf _trisabuf,W
tris PORTA
;;;;;;;;;;;;;;;;;;;;;;;;;;;; BASE TIME
movf _TEMPS,W
movwf _COUNT1
dxxx nop
decfsz _COUNT1
GoTo dxxx
nop
nop
Call delay
Call delay
Call delay
Call delay
Call delay
;;;;;;;;;;;;;;;;;;;;;;;;;;; STOP OF COUNTING
bcf _trisabuf,3 ;RA4 in entry and RA3 at Exit to block counting
movf _trisabuf,W
tris PORTA
If i remove the two code : tris PORTA on asm code at the end of code the pot adjust linear, but the frequency meter
is not show properly.
In the image the resistor is 47omh and the pot 47kohm
